clutch
i've got a 1968 chevy 1/2 ton truck that had a l6 in. but now i have a 1986 350. the fork is maxed out. it does'nt go in gear. what bellhousing , fork or ball. do i need. thanks
![]() Join Date: Mar 2003
Shouldn't matter if you used the same clutch. More info--motor placement, did you use the same bellhousing? clutch? t.o bearing? fork?
If the clutch "Z" bar is in the right position and you are using truck components for the linkage, the most likely problem is the throw out bearing.
There are two different lengths and if you use the short one on a clutch that needs the long one, this problem will occur. Jim |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Did you just use the 6 cylinder flywheel, clutch, throw out bearing, and bellhousing on the 350?
If you kept all of the same stuff together, it has to be a linkage problem. I mean, the clutch worked before you swapped engine right?
#5 | |
clutch
#6 | |
clutch
#7 | |
clutch
#8 | |
#9 | |
