The Older Generation
Picked Up This '71 Chevy Today
I learned on the '66 that you don't post that you bought a truck until you have the title in your hand and the truck on the trailer... ![]() That said, this is Grandpa's '71 Chevy truck. Not my Grandpa, PJ's Grandpa. Grandma gave PJ the truck so he proceeds to tear it apart so he can use the parts on his '69 Longhorn. He took the rear end out, he took the seat out, he took the gas tank out, then he took the engine and transmission out to put the TH400 in his truck. This is what is left... He still has the engine and I think I am going to end up with it.. (I hope) I told him it needs to stay with the truck. I have been dealing on it off and on for two years. It was out of the elements but the rats and mice have been in it. For Iowa it has pretty nice sheet metal. It needs rockers but that is about it. The floor is better than I had hoped for. I went over to the salvage yard and scrounged a rear end and wheels I could use to get it home and the install actually went pretty smooth. The first pictures were taken inside the building, The next ones were on the trailer. I will post more tomorrow after I get it cleaned up. LockDoc
Re: Picked Up This '71 Chevy Today
more
Not too shabby. And,you even get a hoist set-up with it.
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Not bad, is the hydraulic pump for a tilt bed by chance? I guess you can say "Score"!!
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
![]() Join Date: Dec 2012
Subscribed
Very interested in seeing what happens
1971 GMC Sierra 1959 GMC 100 |
Recovering Truck Driver
Your hydraulic pump looks a lot like the one I have for my 67!
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
#7 | |
Thanks Tim, I hope I can get it working.
Thanks Schrum, It will be a while before I do much to this one except clean it up. I have to finish the '70 4x4 first. Chad, if you get back to this thread, does yours work OK? LockDoc
Geeez, Leon! "Leon's home for wayward trucks" Good score! Are you intending to Flip the 4x4? Momma's gonna need a ladder to get in that one!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#9 | |
![]() Yes, the 4x4 will probably go bye bye. LockDoc
Looks like a worthy project.
What is the rack on the front for?
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives ![]() |
Leon, thats a fairly easy system.. first check make sure the motor runs, if yes, check the fluid level and whether its sludge or oil, change external filter and pick up screen (if it has one). It may just need filter and sludge drained and changed.
#12 | |
I think he had the spare tire mounted on it.
LockDoc
#13 |
Here are a few pictures after I cleaned it up a little. I found all of the original tire tools in the pouch in the corner of the cab. The jack was in the cab too. You are going to love the hood ornament... ![]() LockDoc
#14 |
more
#15 |
If you decide to lose those side steps I would be interested for my 1 TON .
#16 | |
LockDoc
#17 |
Looks like a great truck!
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
#18 |
Looks like a good score Leon.
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold ![]() 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
#19 |
The hood ornament looks like a 62 F*** galaxie fender emblem to me
#20 |
6>8 Plugless........
![]() Join Date: Sep 2007
Nice score Leon!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#21 |
Thanks Ryan. I cleaned the carpet. put a gas tank and seat in it, and replaced the drivers side arm rest with parts I had on hand over the last few days.. No luck on getting the hoist to work though. I'm looking for a leaf spring rear end for it so keep me in mind if you come across anything.
LockDoc
#22 | |
#23 |
I can't believe it had the bag for the jack tools, rare item there.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
#24 | ||
I got a spark when I hooked power to the motor but it didn't turn. I imagine the motor is stuck. If it ever cools off here I will pull the motor out and see if it runs on it's own, and try turning the pump by hand. Quote:
LockDoc
#25 |
Yep, sounds like one of the two is frozen. I think the motor is the least expensive of the two, lets hope for that.
