Old 11-02-2013, 06:22 PM   #1
1959Chev
1959Chev's Avatar
Rear differential swap
I have an 85 c10 with a 10 bolt. The rear is making noise so I need to replace gearset in it. I have a 98 2500 2wd truck I bought that I plan on pulling vortec from and sticking in the 85 with fuel injection and a LT4 hotcam upgrade.
My question is will the rear differential from the 98 fit in the 85? I know I will probably need axles but the 85 is peg leg and I believe the 98 is posi or limited slip so it would be a free unit basically. Just need to know if it will fit and what it will take to make it work?
2006 Chevy Silverado 3500(Duaramax/Allison) - DD
1997 Honda Civic - Work Beater
1981 Chevy Malibu - Race Car
1959 Chevy Truck - Project
http://67-72chevytrucks.com/vboard/s...d.php?t=481442
2006 Honda Accord - Wife's ride
1959Chev is offline   Reply With Quote
Old 11-02-2013, 08:07 PM   #2
ont_guy_38
ont_guy_38's Avatar
Re: Rear differential swap
You need special conversion bearings to put that in your housing and also 30 spline axles to fit your housing. You would be better off welding new perches on the 98 rear end and installing the complete thing. It is about an inch wider if that isn't an issue.
1985 C10
2004 Avalanche
ont_guy_38 is offline   Reply With Quote
Old 11-02-2013, 08:17 PM   #3
1959Chev
1959Chev's Avatar
the 98 is a 3/4 ton with 8 lug.
Old 11-02-2013, 10:08 PM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
Pinion yokes may be different then.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-03-2013, 07:25 AM   #5
ont_guy_38
ont_guy_38's Avatar
The 454 ss had a 14 bolt with 5x5, maybe the axles would fit ?
1985 C10
2004 Avalanche
Old 11-03-2013, 08:32 AM   #6
Rascal_one2001
Rascal_one2001's Avatar
good luck finding the 5x5 14 bolt sf axles if you have a 14semi floater. your a lot better off finding the correct unit. it will be a lot cheaper and nicer in the long run
1985 1500 454, 4l80e, 12 bolt, 5/6 drop, 20s
Rascal_one2001 is offline   Reply With Quote
