Old 02-06-2008, 09:32 AM   #1
nhtc33d
Manual trans.w/a z'd frame
How hard would it be to run a manual trans. with a z'd frame?
how would you do the clutch linkage?
nhtc33d is offline   Reply With Quote
Old 02-06-2008, 02:54 PM   #2
kdrodworks316
KOFFIN DRAGGER
kdrodworks316's Avatar
Re: Manual trans.w/a z'd frame
my frame is Zd' 3 1/2" and I have a 4 speed with a hydaulic clutch. watch how much you Z, the previous owner done a doozy on the truck I got, wiper motor sits on top of distibuter cap. You also have to modify the x member so the driveshaft clears. check out www.porterbiltstreetrods.com for the right way to slam your truck.
kdrodworks316 is offline   Reply With Quote
Old 02-07-2008, 01:11 AM   #3
1LoC10
Insert Title Here
1LoC10's Avatar
hope its not a 3 on the tree
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 02-07-2008, 02:39 AM   #4
thekid54
My frame is Z'd 3" and I'm running a manual trans with the 3 on the tree, what's the big deal? I have a hydraulic clutch so I don't have to worry about clutch linkage.
thekid54 is offline   Reply With Quote
Old 02-07-2008, 09:05 AM   #5
nhtc33d
I was thinking a 4" Z will that cause any problems with a small block? I am going to run a 250 6cyl. for awhile but i dont want to have to do any mods to put the sb in. What type of hydraulic clutch are you guys running and where are you mounting it at? (pictures if possible) Thanks
Old 02-08-2008, 12:14 PM   #6
nhtc33d
It's a 3 speed but I'm going to put a floor shifter in.
Old 02-08-2008, 02:08 PM   #7
thekid54
My '62 came stock with the hydraulic clutch. It uses a dual chamber master cylinder. One is for the brakes, the other for the clutch. The m.c. is connected to a slave cylinder that's mounted on the bell housing, which actuates the clutch fork.
Old 02-08-2008, 09:43 PM   #8
nhtc33d
That sounds like what I need! Can you run a disc brake setup with that master cylinder also?
Old 02-09-2008, 12:43 AM   #9
LILRED66
LILRED66's Avatar
If converting to discs on the front and factory drums on the rear, you will need a power brake booster, as well as, a dual chamber master cylinder with a porportioning valve. The factory dual chamber master cylinder may not work in conjunction with this setup.
CPP and several other aftermarket truck parts suppliers offer the power brake booster, dual chamber master cylinder and the porportioning valve, all designed to work in conjunction with each other.
LILRED66 is offline   Reply With Quote
Old 02-09-2008, 02:44 AM   #10
thekid54
Yes, that is what I have. It's pretty expensive, but a huge time saver. Just bolt it up and go. The only thing I don't like is how far it sticks out from the firewall. The CPP unit just uses a generic Wilwood m.c. for the clutch. You can make your own setup (see the 2nd pic for an example), but it takes some creativity to get the pedal linkages setup.
Old 02-09-2008, 05:06 AM   #11
nhtc33d
That's a nice looking setup you have. It looks like I am doing the same thing that you have done already! So if I understand correctly...
1. If i keep my drum brakes w/drop spindles i can use a stock duel chamber M.C.
2. if i want disc brakes i need a aftermarket D.C M.C power booster
Thanks!
Old 02-09-2008, 07:49 AM   #12
thekid54
^Simply put, yes, your assumptions are correct. However, there's a lot more to it. I'm betting your bell housing is not setup to accept the slave cylinder and your clutch fork is probably on the driver's side? You would have to fab. a bracket to mount the slave cylinder. It's kind of hard to make out, but if you look just below the starter and to the left in the pic you can see the slave cylinder.
Old 02-09-2008, 09:31 AM   #13
nhtc33d
Your right! So If I understand correctly I have 3 choices....
A. Get a new bellhousing with a pass. side clutch fork.
2. make a bracket for my driver side clutch fork.
3. Buy a automatic transmission!!
Old 02-09-2008, 09:49 AM   #14
thekid54
^You got it.
Since you're running a 250 and eventually a 350 and you're running a floor shifter, I'd go the automatic route. Just my 2 cents.
Old 02-09-2008, 09:58 AM   #15
nhtc33d
I really appreciate all your help!
Guess I'm in the market for a glide or th 350!
