09-02-2011, 08:29 PM | #1 |
Ford np205
Looking for some help. Tried searching but couldn't really get what i was looking for, i know its out there just cant find it. Im getting a np205 from a ford bronco, i dont know the year. I have a 79 k35 with a th400 and a np203. What will i need to make the 205 fit my truck. Ive been doing some searching and know the splines will be different. Also i will need a different tail shaft for the th400? Anyone else done this swap? Are the ford 205 way different that the chevy 205? Thanks!
09-02-2011, 09:20 PM | #2 |
Re: Ford np205
Ford np 205 are Driverside drop. Trade it for a GM 205.
09-03-2011, 12:17 AM | #3 |
Re: Ford np205
is there a way to pass drop it?
09-03-2011, 01:03 AM | #4 |
Re: Ford np205
09-11-2011, 11:43 PM | #5 |
Re: Ford np205
If you want to run this transfer case you'll have to count the splines and figure out what you need, as well as find a Ford front axle. Worthy swap if you come across a Dana 60 HP, but they're not cheap and definitely not easy to find.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 |
09-12-2011, 08:10 AM | #6 |
Re: Ford np205
The combo you have now will only work with what you have now. The 203 version of the TH400 bas a stickout of an inch, only work with the 203. In order to run a 205, will need the matching adapter and 205, which there is two versions.
Im looking for a 203 and possibly a 400, where in PA are you? Posted via Mobile Device
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
09-14-2011, 07:37 AM | #7 |
Re: Ford np205
You could connect the 205 to the gearbox of your 203 with a doubler kit from Offroad Design then change your front axel to a high pinion ford dana 60 . It's been done .
09-14-2011, 10:13 AM | #8 |
Re: Ford np205
09-14-2011, 11:48 AM | #9 |
Re: Ford np205
If it was divorced u could
09-16-2011, 12:58 AM | #10 |
Re: Ford np205
You could physically flip the case for a pass drop, but you will have oiling issues. If it were a dedicated crawler, I would consider it if the budget was next to nothing. Pull the input shaft and the 32 spline front output for later doubler use and find a GM 205 to run with what you have now.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers '66 C10 - The new hot rod '77 3+3 Dually - 12 valve 4wd conversion tow rig project '28 Ford 2 door sedan street rod RevLimit Offroad "Hang on beer, we can do this." |
09-16-2011, 07:53 AM | #11 |
Re: Ford np205
If it was a divorced case, and the input side is machined flat, you can drill/tap to whatever pattern you want. Well, 6 bolt round at least. Change the input to correlate with your adapter, mod for the shifter, couple other misc stuff, done.
09-16-2011, 05:24 PM | #12 |
Re: Ford np205
So much easier and cheaper to find a GM 205.
09-18-2011, 08:09 AM | #13 |
Re: Ford np205
Yes it would!! But just saying there are options. To the o/p, Where in PA are you??
