Old 11-12-2014, 11:27 AM   #1
rossboss
rossboss's Avatar
door locks?
On the drivers side door the key slot is verticle unlocked and horizontal locked, but on the passenger side the slot is just the opposite unlocked is horizontal and locked is verticle. Is this right because it sure doesn't seem right or does one need to be turned 90 degrees if possible.
rossboss is offline   Reply With Quote
Old 11-12-2014, 12:01 PM   #2
65 C20
Re: door locks?
I'm not a locksmith so don't know how to change it but mine are both vertical when unlocked.
65 C20 is offline   Reply With Quote
Old 11-12-2014, 04:06 PM   #3
Larry64
Re: door locks?
^^^^^^^^^^^^^what he said
Larry64 is offline   Reply With Quote
Old 11-12-2014, 07:05 PM   #4
disasterbus
Re: door locks?
mine only has a key slot on the driver's door, no key slot at all on the passenger side - you have to lock and unlock it from inside. Is that normal?
disasterbus is offline   Reply With Quote
Old 11-12-2014, 09:30 PM   #5
lowbuck
Re: door locks?
The door lock key slots should both be vertical in the unlocked position. If you want to fix it the door handle will have to come off and be taken apart. There is a snap ring and spring that you will have to remove. The cup on the bottom will then have to be repositioned into the proper spot. I don’t have one to send some photos. If you search on LockDock’s postings there are some photos of a rear tail gate lock.
lowbuck is offline   Reply With Quote
Old 11-12-2014, 09:40 PM   #6
Micmac
Micmac's Avatar
Re: door locks?
It is on my 1963.
1963 Chevrolet C-10 "Ginger"
1970 C-30 Dump Truck "Scarlet"
2019 Chevy Silverado 2500 Z71 LTZ
1947 Indian Chief Roadmaster with Sidecar.
2012 Indian Chief Serial #002 of 110 built in '12
2016 Indian Chief Roadmaster
Micmac is offline   Reply With Quote
Old 11-12-2014, 10:05 PM   #7
VictoriaHardware
VictoriaHardware's Avatar
Re: door locks?
That is normal for the base truck. A keyed right side door was an option- usually part of the Z62 Comfort or Convenience Package. I have a '66 where is was actually a stand-alone option A94, Safety Door Lock Equipment.
VictoriaHardware is offline   Reply With Quote
Old 05-12-2015, 03:32 PM   #8
akqj9
Re: door locks?
My 1964 C10 has only a driver's side lock. I want to put a lock on the passenger side in case the driver lock ever jams. Can I get it keyed the same as the ignition?
akqj9 is offline   Reply With Quote
Old 05-12-2015, 03:52 PM   #9
1963c-10
1963c-10's Avatar
Re: door locks?
You can order the lock....take the new lock, your driver side lock and the ignition to a locksmith. They can key them the same.
I have my doors and ignition keyed the same, only my glovebox is keyed different, but I plan to take that down and have it keyed the same also.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-13-2015, 06:59 AM   #10
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: door locks?
RPO A94 or Custom Comfort Option RPO Z62
Old 10-11-2015, 09:59 PM   #11
canonball
canonball's Avatar
Re: door locks?
I know this is an old post, but I'm in a similar, but different, position. On my '63 GMC 1/2 ton, I have a keyed lock on the passenger side but a blank on the driver's side. So I have to get in and out of the passenger side, which is slightly annoying. Where's the best place you guys recommend to pick up a new lock cylinder?
canonball is offline   Reply With Quote
Old 10-11-2015, 10:19 PM   #12
akaupp
Re: door locks?
I got mine as a complete set, both doors, ignition and glove box from the Truck Shop.
Aaron
1964 K10
1964 C10
1965 Suburban
2005 Yukon
akaupp is offline   Reply With Quote
Old 10-12-2015, 12:27 AM   #13
Fredthecat
Re: door locks?
What's required to install locking cylinder in base model passenger side handle besides just the lock cylinder?
My "old" cars all have lock cylinder ONLY on passenger side. Was told you were supposed to ingress/egress on curb side (not in street) and slide over.
Fredthecat is offline   Reply With Quote
