06-13-2014, 07:02 PM | #1 |
Front Radiator support
How do you remove the front Radiator support bolts that bolt to the frame? I have the nuts off but the bolts will not come out.Need Help
06-13-2014, 07:18 PM | #2 |
But Found Her 25yrs Later!
Re: Front Radiator support
put the nuts back on and tap the bolts loose.
They are probably rusted to the radiator support after all these years.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
06-13-2014, 07:25 PM | #3 |
If they are rusted to the support what then.
06-13-2014, 07:27 PM | #4 |
If you have to hit them hard enough you ruin the bolts, you can get new aftermarket ones.
06-13-2014, 07:46 PM | #5 |
who sells aftermarket bolt kits with the rubber bushings,washers etc.for the support. I have seen cab mount and bed bushings but not radiator support bushings.
06-13-2014, 07:50 PM | #6 |
06-13-2014, 08:06 PM | #7 |
I appreciate your help. I ordered a set .Thanks Lewis
