5.3L Swap?
I've recently found a used 5.3L engine and automatic tranny from a wrecked '01 suburban for about $1500. My '79 C20 currently has a 454/TH400 that has been around the block a few (hundred thousand) times.
As much as I love having a 454, the 5.3L is the same torque and 80 more HP stock than my 454, much more reliable, and probably gets at least twice as good of mileage. Would the 5.3L and tranny by chance be a bolt in for my truck? I've been pondering a fuel injection swap for the 454, but a whole drive train swap probably would hardly cost more. Decisions decisions.... |
Happy to be here
![]() Join Date: Mar 2000
No, it is no where near a bolt in. It may be worth the trouble, but it will take a decent amount of expense and effort to convert to any of the LS based motors. You will need the motor, transmission, computer and harness for starters. Then you will have to have the computer and harness modified along with different motor mounts and transmission mounts. And that's the short list.
If your looking for the easiest route you should consider a GM crate motor as a replacement for what you have...
#3 | |
#4 | |
driving is in my blood
![]() Its not worth the hassle IMO. It would be so much easier to put a FI vortec 350 in there or just the vortec FI from a big block on your current 454. Again were not saying it can't be done, but its difficult. I belive n2trux's has done this swap or was going to on his blazer.....
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
Happy to be here
Tom is correct. Even though the cost has come done quit a bit since I did the LS1 conversion in my Blazer your still going to spend 3-5 k by the time it's all done.
I'm not trying to discourage you, just warn you that the cheap price of the motor is just where your expenses begin. Last edited by N2TRUX; 04-28-2005 at 11:11 PM. |
#6 | |
What could possibly add up to $1500? So the motor mounts are a little different...that's not a big deal. I found this page in google, which says:
Do it !!!!!!!!!! Next engine in my 85 is going to be a duramax deisel !!! Think I'm crazy for spending $5,000 for the duramax,allision,t-case setup . maybe have to go another 1,000 in extras. Well when it's putting down 400 hp and 700 lbs of tq and getting close to 20 mpg for the next 250,000 miles I will be all smiles.
#8 | |
Trucker.
http://www.hotrodlane.cc/77chevytruck/77chevy.htm Last edited by Izzy; 04-29-2005 at 12:27 PM. |
Until Seventy Times Seven
As the others have said, it is not a direct bolt-in but it is doable if you can handle the effort and the expense. Add to the short list: fuel pump(s), radiator and possibly the oil pan/crossmember issue. Sounds as though you have access to all the accessories, computer and wiring harness. You can get an aftermarket company like Speartech to modify your harness. Fiveeight's reference to Street & Performance's LS conversion is a good link. They have write-ups on other LS conversions that they have done on their site. Beware, their writeups make the conversion sound easy. There's a few of LS forums that have good information on LS conversions like LSTech. More folks are doing the LS conversion in many different types of vehicles. It takes a good bit of time to do the swap, but the results are impressive. Good luck in your decision.
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
