Old 10-20-2007, 11:37 PM   #1
68burb
swapped from k10 to c10 need combo pics.
I'm picking up a front crossmember set up tomorrow to continue the conversion.
I know I want to air bag it but want to see rigs with and without dropped spindles to see the difference if I can get low enough.
I want to run either 18-19's or 20-22's on it.
I saw a write up once on knotching the front crossmember and modifying it to set higher up in the chassis for a lower stance, anyone have a link to the like??
also how low can you go before there are steering issues and sway bar problems (bracket less swaybars and swapping to rack and pinion steering)
1968 K10 burb- on it's way to being C10 sporting a 454 th400 and LTZ 20's
1995 K2500 Burb as daily driver 350 with 193K miles
1994 K1500 Silverado ECSB building a TBI 350 for it 330 horse
68burb is offline   Reply With Quote
Old 10-21-2007, 03:05 AM   #2
earl87gta
earl87gta's Avatar
Re: swapped from k10 to c10 need combo pics.
your already a step a head the k10 front has more of an arch init then the c10 so you will allready have a drop member with out doing any thing diffrent. the blazer guys that do the convertion alot I would go check out there convertion threads for good info on this. this is probly the best do it your self drop meber thread http://67-72chevytrucks.com/vboard/s...ht=Drop+member
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
