Old 04-06-2008, 11:44 PM   #1
Chevy Eleven
Chevy Eleven's Avatar
Noobie with a wheel question
Hello guys I am new to posting to not new to reading and learning. I bought a 63 C20 for a beater, and it is slowly turning into a project (thanks to all ) First things first...she needs a drop. My questions is the truck has 15" 2 Piece Wheels. Is this normal for this model? Are these useful to anyone or are they scrap? I am unfamiliar with 2 piece, but I know no one will mount tires on them, so I bought some from a junk yard to replace them. I am in the process of painting the bumpers, grill, and getting the wheels on. I need to do a bit a rust repair as she has bad spots on doors and fenders. Cab is SUPER corners are great and rockers are solid. Needs a patch in the floor by the tank on both side and that is about it. Anyway thanks for all the information and hope to get to know you all soon. And I better post a picture or two huh??
Chevy Eleven is offline   Reply With Quote
Old 04-07-2008, 12:37 AM   #2
joe231
joe231's Avatar
Re: Noobie with a wheel question
wheels are junk imho, scrap them......
WELCOME ABOARD!!
this is a great site with lots of info...
the search feature will be your best friend!
CHEVY ONLY
Old 04-07-2008, 12:42 AM   #3
SeanPaintsFlames
SeanPaintsFlames's Avatar
Scrap metal. You could sand blast them and make barstools!
Are you keeping it an 8-lug, or switching to 5 or 6 when you drop it? That would certainly open up your wheel options.
Check this out for drop parts if you haven't found it already!
My 68 cougar restomod build:HERE
SeanPaintsFlames is offline   Reply With Quote
Old 04-07-2008, 03:05 AM   #4
Chevy Eleven
Thanks for the info guys. SeanPaintsFlames thanks for the link. I will hopefully find a 73-87 donor and convert 5 lug...see this is how addiction starts, buy a beater and first the paint then wheels then the lowering and on and on.
Old 04-07-2008, 03:30 AM   #5
protrash64
Resistance is Futile
protrash64's Avatar
You've gotta save at least one wheel for a homemade hose reel!!!!! Good luck w/ your truck.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 04-07-2008, 03:43 AM   #6
truckn'
truckn''s Avatar
welcome aboard from East Tennessee where abouts are you located?
truckn' is offline   Reply With Quote
Old 04-07-2008, 03:59 AM   #7
Chevy Eleven
Good Ol' Kingsport...I go to Rogersville all the time, that is where I got the truck actually.
Old 04-07-2008, 04:13 AM   #8
Fred T
Cantankerous Geezer
Fred T's Avatar
If you do scrap the wheels save the hubcap clips. No one is making them for the 3/4 ton, and us older model guys can use them when we want to put original caps on a newer rim.
I am still running the two piece rims on my 52. Unfortunately, they got caught in the 3 piece rim fiasco in the early 70s. The 2 piece lock ring has a very low failure rate. The only was one will come apart is if you really screw up on assembly or have severe rust. They were made so a farmer could change the tire with a hammer and a bar. I have a local dealer who does mine, but it's an extra $5 a wheel. I repaired truck tires during wheat harvest just out of high school.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 04-07-2008, 01:45 PM   #9
LILRED66
LILRED66's Avatar
Whether 5, 6 or eight lug, the wheel options are almost unlimited...don't change from 8 lug to 5 or six lug, thinking you have more options, because most of the major manufacturers have every size, style and finish, to satisfy your wheel needs, so don't change because you believe there are limited options, because there are near limitless options. Good luck with your build.
LILRED66 is offline   Reply With Quote
Old 04-07-2008, 03:45 PM   #10
baddawg65
baddawg65's Avatar
Might check to see if anyone is doing a show quality restore, and wants the correct rims. But I wouldn't change bolt patterrn because of wheel selection. But if you do, since you hane an older 3/4 ton it wll probably have an eaton differiental with 17 spline axles. I found out the hard trying to find a locker. Good luck and welcome onboard.
baddawg65 is offline   Reply With Quote
Old 04-07-2008, 07:23 PM   #11
Chevy Eleven
Thanks guys for the information. Looks like I am going to put the wheels in storage for a bit and hang on for the swap right now...thanks again
Old 04-08-2008, 07:26 AM   #12
oldblu65
oldblu65's Avatar
Welcome from southeast Tennessee , Chattanooga area !
oldblu65 is offline   Reply With Quote
