10-09-2005, 08:12 PM | #1 |
Dropped Spindle/Brake Hose
I'm a 67-72 guy but have upgraded to 73+ front suspension. Using ECE 2 1/2 dropped spindles with 73 1/2 ton brake calipers(SAE threads not metric). I can not get the brake hoses to fit. The hose is 73-77 1/2ton 2wd but just doesn't fit under the upper ball joint. It looks like the 90 bend should be more like 110degrees. The spindle has a strengthening boss that is cast to help support the upper ball joint. It is in the way.
I called ECE and the guy was very nice but said "maybe a little tweak" might be needed. A 30degree bend does not seem like a "little tweak". What have you guys used for hoses or what is my problem? Any help would be appreciated. Thanks - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
