manual shifter getting stuck
shift linkage gets hung up and won't shift out of low. any fix for it? 3 on the tree.
1961 Apache short step. |
Senior Enthusiast
Re: manual shifter getting stuck
This why so many old 3 speeds ended up with floor shift conversions. The original design wasn't all that bulletproof to begin with and over time as the parts wear they are prone to getting stuck. This older link may help if you decide to try and rebuild the linkage and need bushings, but it's usually the components in the shift mechanism on the column that wear out:
http://67-72chevytrucks.com/vboard/s...d.php?t=291859
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
just found the upper bushing that is missing on mine. Place called Bob's Chevy trucks. $2.88
i think obsolete chevrolet sells all of the grommets for the three speed column shifters.on the column section and also where it hooks up to the transmission.google obsolete chevy and you will find their website.do not know if they are listed online or not,but they do have them in their catalog.good luck
Six in a row makes it go...
![]() Join Date: Mar 2009
I had a '68 Chevy Biscayne that I got with 26,000 original miles. It had 3-on-the-tree. I kept the linkage greased regularly. Never had a problem - shifted like glass...
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I always rebuild the linkage with new bushings and never have any issues.
Classic Parts sells everything you need for well under 20 bucks.
Airport Bum
That is theft prevention.
![]() Well just having a 3 on the tree is good, since most people can't/never drove one. My truck was like that for years, and only I could drive it. ![]()
1964 Chevrolet C-10 1941 Chevrolet coupe 1962 Thunderbird 1959 Edsel Villager 1963 Skylark |
