Old 07-17-2012, 12:07 AM   #1
Cash3481
Loves all GMC trucks
Cash3481's Avatar
Entire BB and tranny swapout with accessories
Im going to offer everything to make the BB switch out from whatever vehicle you currently have. I believe I have removed everything as far as the drive train goes to facilitate a seamless conversion to a BB swap.
Here is whats included.
1. High Hump with bolts
2. BB Fan Shroud with clips
3. Automatic Crossmember
4. 72 Pedal with Switch and harness
(harness is not the greatest but I may have another)
5. 4 core radiator hold downs (top and bottom)
6. Vacuum line to booster
7. BB Stands and clamshells
8. BB Shift linkage
9. All 6 Exhaust hangers with clips (missing one ruber isolator)
10. passenger side bb Heat shield
11. Engine Harness
12. Turbo 400 tranny
13. Entire 72 engine from air cleaner to oil pan with all asscessories.
i.e. Power steering pump, alternator and water pump with brackets attached.
I made a video of it running in the truck and will get it loaded for view tomorrow evening. It held great oil pressure at startup and after its warm both. The water pump shaft is noisy and squeeks a little at about the 1.15 mark but I can assure you the engine is sound. I drove this truck 20 miles at about 70 and around stop and go driving in town for 20 minutes last thursday, it ran fine on both trips. I also let it sit and idle on a 95 degree day for 20 minutes. If the water pump scares a potiential buyer ,I can replace it to assure the sale.
Today (16 July) I pulled the engine and am offering it here for $1400 as a bundle.
Why look all over for these parts when you can get them all at once?
If it doesnt sell together I will be parting this out in a week.
Cash3481 is offline
