Old 06-18-2013, 02:16 PM   #1
67c10rustbuket
67c10rustbuket's Avatar
UCA contacts spindle when chassis on jack stands.
Almost done with my front suspension when I noticed the upper control arm contacts the spindle when suspension is hanging. This keeps the spindle from turning when on jack stands. Is this normal?
Specs:
67 C10
Stock C-arms (w/original alignment shims installed on uppers)
New Moog shafts
New Moog ball joints (73+)
New upper and lower bump stops
New Western Chassis 2.5 drop spindles (73+)
New 1" drop coil from Brothers trucks
See the blue tape at the contact point in the pic. Any thoughts? I don't have anything older to compare it to.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 06-18-2013, 02:19 PM   #2
67c10rustbuket
Re: UCA contacts spindle when chassis on jack stands.
This contact clears as soon as I get the first pump on the jack under the lower control arm. Just thinking if I were to go dukes of hazard jumping I would not be able to turn the wheel in the air. yes I am joking, no plans of jumping it.
Dan <---(my name)
Old 06-18-2013, 04:15 PM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
My guess is to trim the flange up or grind down the rib on the spindle. I think the earlier arms had wider flanges than later arms.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-18-2013, 11:39 PM   #4
wraprail
wraprail's Avatar
My guess is the factory upper control arm bumper/stop has been changed or removed.
wraprail is offline   Reply With Quote
Old 06-19-2013, 01:35 AM   #5
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Very common problem with western chassis spindles.. I have always had to trim the upper control arm when using them..
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 06-20-2013, 10:44 AM   #6
67c10rustbuket
Thanks, Might have to do that.
Yup, Bumpers are brand new. Everything is brand new. Nice truck BTW
Thanks Kyle, Not the answer I wanted Which spindles do you recommend?
Just thinking a bit, I found one of the original upper bumpers and will put it back in to see if it compresses less than the new ones. If so maybe using energy suspension bumpers would give it just enough clearance. Probably have to trim the upper arm anyway but might be worth a shot.
I think I learned a good lesson for the next project: remove old front suspension, replace with tubular arms maybe replace complete suspension crossmember. The amount of money I have in this stock-ish front end is getting real silly.
Dan <---(my name)
Old 06-24-2013, 09:32 PM   #7
72MARIO
72MARIO's Avatar
same here
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 06-24-2013, 11:35 PM   #8
67c10rustbuket
Taking at apart to trim the uppers in the morning. Yay ! Gotta love cutting powder coated parts.
Dan <---(my name)
