Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech
Old 12-13-2014, 01:24 PM   #1
yote1234
yote1234's Avatar
how i set my cab on .......solo
I call it "Bud Lite" engineering! c-clamped (2) 4x4x12' wood posts along my 4-post lift. add 16 small 2x4's under cab windshield lip, and lift! roll chassis under cab and lower!
than have a few cold ones to celebrate!
1971 K5 CST Blazer
1965 Chevelle Malibu 283
1968 Camaro 327
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is offline
Old 12-13-2014, 01:25 PM   #2
yote1234
yote1234's Avatar
Re: how i set my cab on .......solo
more
1971 K5 CST Blazer
1968 Camaro 327
1966 uh 1-D Huey
yote1234 is offline
Old 12-13-2014, 09:26 PM   #3
theastronaut
theastronaut's Avatar
My redneck version of solo cab mounting...
theastronaut is offline
Old 12-14-2014, 04:29 AM   #4
Grizz1963
Grizz1963's Avatar
Actually a great "resource thread" this.
We all learn from here.
This is copied and pasted from my thread when using my buddy Martin get his cab off.
Built the jig, based on one I saw on here.
Video clip shows how easy it works too.
I spent about 5 hours over at mate Martins place today.
We removed his cab, which has set me thinking that I should maybe remove mine as well, to get better access to the underside of the chassis.
On removing the cab, he found a lot more rust, terrible historic patches an a load of sand inside the chassis outriggers.
I will post up the pics to tell the story of getting the "special tool" in and moving the cab away.
Final inspection before removing the last two chassis mounting bolts.
One broke off, despite all preparation.
Lifting jig fitted to three ton hoist.
VIDEO IN LINK BELOW
AND THIS IS HOW IT WAS DONE:
https://www.youtube.com/watch?v=Lxcu...lt8TvG8KEwT5Kg
IMPRESSIVE STUFF, AND RESULT.
Next up we parked the cab out the way, the trolley needs another 24 inches of height, which will happen later.
Farmer Brown........
Lastly Martin removed the welded on front bumper and the truck was put back into its tight spot.
That was it for this weekend.
As we go on working together, I am learning more and more.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline
