02-22-2011, 09:46 PM | #1 |
Notched the frame...a little
Hey guys, I was looking for some opinions on the structural integrity of notching the frame for header clearance. My plan for the truck is a weekend cruiser and the occasional smokey burnout. Of coarse I will have to take it down the track at least three... times to establish talking points. I am leaving the suspension stock with the exception of the lowering shocks and springs now on the truck from cpp. Sometime in the future, I may add disc brakes as well. Should I maybe box weld in some steel where I notched the frame for the intended purpose of the truck as stated? The converter is questionable once I get the truck running, so a engine pull could be in the future. I am still a long way from firing her up. Thanks, Bill
02-22-2011, 10:01 PM | #2 |
Re: Notched the frame...a little
cool a olds, i am so glad some one put something in besides a small block chevy. grate job .
i have been wanting a buick nail head in one of mine . keep up the good work.
Between saying and doing many a pair of shoes are worn out |
02-22-2011, 10:06 PM | #3 |
My K20 had the frame notched to clear the headers and I never saw an issue with it.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
02-22-2011, 10:13 PM | #4 |
Olds in a chevy..i love it, what cube is it?
02-22-2011, 10:17 PM | #5 |
Second Chance Program
Should be fine by the looks of things. Very cool.
02-22-2011, 10:55 PM | #6 |
Thanks for the reply's. It's a 455.
02-22-2011, 11:25 PM | #7 |
No problems there. 455's have some grunt. My old roomate had one in a 71 (or 72?) Cutlass. Mild compression & decent cam, it pulled hard.
02-23-2011, 12:35 AM | #8 |
60-66 Nut
No need for re-enforcement. Good job with the nice rounded notches. Keep us posted on your progress.
12-14-2011, 11:25 PM | #9 |
Update.
After hours of work, ( as an amateur) I finally have the outer floors, lower fenders, rockers and cab corners replaced on my 65 fleet-side short bed. No formal training, just bought a wielder read some information and tore into it. I would like to thank everyone on this site that has expressed their knowledge and encouragement for others. I love the pictures that everyone posts and I know it gives me the motivation to try things I had never done. I am still not decided exactly the direction I am taking this build. I knew that I personally couldn't live with rusted out floors and rockers. I know I want a Flat paint, or even thought about a wrap, but I don't think a wrap will last for the long run. Thanks again. |
12-14-2011, 11:33 PM | #10 |
A few more.
12-15-2011, 11:56 AM | #11 |
It's Better With Nitro
Very cool! I had to trim the top portion of my frame, as well (running a Pontiac) to clear the header primaries.
12-15-2011, 11:58 AM | #12 |
Nice looking work on both the engine and the body
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
12-15-2011, 06:31 PM | #13 |
Looking good! makes ya feel good to do it yourself huh!
My build link.. http://67-72chevytrucks.com/vboard/s...d.php?t=285353 |
