Stupid question #59
(this is my 59th post)
Driving home last night sitting in traffic I was taking a closer look at my gas gauge and noticed two reddish lights that I never saw before. I have never seen them come on and I have no idea what they are for. here is a pic.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
Dummy lights one is for brake and one is for temp overheat.
1971 GMC K1500 SWB Fleetside, 4" skyjacker softride and, 14 Bolt FF, HD Dana 44 4.10's 1970 K5 TBI conversion lifted etc SOLD 1968 C20 camper truck SOLD “To ban guns because criminals use them is to tell the innocent and law-abiding that their rights and liberties depend not on their own conduct, but on the conduct of the guilty and the lawless.” Jeff Snyder |
I would say that your fuel gauge is from a larger truck c50 or greater as they had those dummy lights
#4 | |
Member since 2000
eh? my blazer had the same thing..... |
More Cowbell....
I have those lights in my C-10 and the cluster has never been replaced.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
#6 | |
FYI: it is the stock guage from a 71 c10
its all about the +6 inches
they ALL had those lights.
The brake one should work the temp one should only work if you have the base model inst pannel...the 3 hole one. In the bigger trucks, the brake light was replaced with overspeed |
So should the brake light go on when the Ebrake is on? Or go on when the brakes fail?
brake failure
More Cowbell....
If the brakes fail.....do you REALLY need a light to tell you????? It's usually too late anyway.
My brake light come on once..EVER. The Master cylinder was almost empty, I fired it up, and started out of the shed. Hit the brake, it went to the floor, and the light came on. I was impressed that it even worked.
Questionable
I have those lights also. They both come on while starting up the engine. The brake light *doesn't* come on when the e-brake is engaged though.
![]() Either way, ... my '68 C-10 has 'em. I'll snap a photo of them on and post ![]()
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
the brake light *should* also some on when you crank the engine over...I've only seen one that actually still did it though.
it it is working properly, it'll alert you when one side is lower than the other, way before you'd feel it in the pedal. It's helped me quite a bit when i leakey wheel cylinders in the old GMC. |
#13 |
Where's my beer?
One more dumb add on here. Is there a high beam light on an idiot light cluster? If I have one it doesn't work.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
#14 | |
Listening since '86
BTW - my brake light comes on just before I start the motor, surprised it still works.
2007 Saturn Aura - hey it WAS a GM product Last edited by JoetheMobster; 03-11-2005 at 01:52 PM. |
#15 | |
This design makes sense. How else, with 1967-1972, could you get a signal telling you about a failure? That system along with the divided master cylinder allow you to have brakes in case of a failure. If a failure occurs in say the rear, all that fluid will eventually drain out but only that half of the system. Then the porportioning valve moves to close off that half of the system, and the light turns on. By the time it gets to that point most folks would have noticed the puddle near one of the wheels or caught a low half of the master and addressed the subject. Checking brake fluid should be done at EVERY oil change. Along with all the other fluids in the vehicle.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#16 |
Where's my beer?
Thanks Joe, I'll check mine out tonite.
Pete
#17 |
![]() Join Date: Sep 2001
That's the wire plug in the bottom of the regulator.
Might be a nice-n-easy mod to have the light also come on when the parking break is set? Just a reverse push button switch behind the brake handle that is pressed in (no electric current) when the brake is not set and the circuit is closed (powering the light on the dash) when the handle is in the forward position... |
#18 |
Questionable
Here, here are some pictures from my truck taken a few minutes ago.
At the top of the speedo, the red square is your high beams indicator. At the bottom of the gas gauge, those are the two gauges in question. Longhorn - now you've seen two of them ![]()
#19 |
Where's my beer?
Shifty, that's a damn clean looking instrument cluster!
#20 |
Questionable
Thanks. The whole truck is pretty clean. It just sucks the person who "restored" it did a pisspoor job of getting rid of the rust, they just painted over some of it (it has at least three coats on it that I can see now)
If you want to see the whole truck, it's really clean, I just bought it for $4000. You can see some pretty rough pictures if you click on the link in the signature of my post.
#21 |
Nice clean truck shifty. How's the power / fuel economey with the 6 ?
I got a bench seat baby, you don't have to sit over there. |
#22 |
Questionable
I'm not sure. I just bought it last friday
![]() I filled the tank @ the gas station after buying it and drove it back to the house (~30 miles) I then drove my girl around my neighbourhood and today I drove it to work. The gas gauge you in the picture I posted above is exactly where the gas gauge rests...so - It took about 45-50 miles to put that dent in it. I don't know if that's good or not. I *can* tell you this - it's burning rich. I'm not sure why, I haven't played with it yet. I'm curious what it will do when I get it a little more towards the lean side. Overall, I'm happy. (I don't know what size my tank is, though)
#23 |
Resident Curmudgeon
![]() Join Date: Dec 1999
Stock tank is approx 20 gallons. An I6 should do between 12-15 mpg around town. On the highway, I have managed to get around 18mpg with 3:73 gears.
Your mileage may vary. ![]()
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
#24 | |
graphic designer
#25 |
I did a poll on this a couple years ago...seems there is no rhyme nor reason.
