Old 09-03-2004, 07:11 AM   #1
norville
Some electrical help please.
Hey folks,
#1 My right turn signal does not blink. Left works good. The blinker cam is busted but should I look somewhere else before I pull the steering wheel?? The lights all work. Does the blinker relay have a left and right or should I look for a bad ground?
#2 Any problem with dumping my external alt for an internal one?? I seem to have a 0.2A draw from the external reg that's draining my battery. What else should I get while I'm at the store?
#3 I have a hard time starting the truck after it's been running for a while. I figure it's a combination of the battery getting low and a hot starter.
norville
1986 C10 Scottsdale
5.3, TH400
norville is offline   Reply With Quote
Old 09-03-2004, 10:41 AM   #2
Senator350
Senator350's Avatar
i had almost the exact same thing happen to my truck. the left blinker wouldn't blink, but only wouldn't when my headlights were on. i had the same minor draw from my EVR too.
you're on the money. chase the ground for the blinker. swap to internal reg alt. don't know about the starter though. hope this helps
RN U OVR
Senator350 is offline   Reply With Quote
Old 09-03-2004, 10:43 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you sure there isn't a bad bulb on the turn signal? Turn on the 4 ways and see if that one comes on. If the bulbs are in fact good, then you have a ground issue.
I say this becouse it is uncommon for the lights to work with a bad ground.
Old 09-03-2004, 01:34 PM   #4
krazy_texan
krazy_texan's Avatar
make sure that you are making good contact to the bulb, i had a similar issue once and i took a round wire brush and cleaned off the contacts inside the socket and in on the bulb.
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 09-03-2004, 01:57 PM   #5
norville
Thanks for the leads folks.
one more thing the turn signal lights up with the lights on just no blinky. I have not tried it wih the lights off. I believe it worked with the lights off??? I can't heard the relay either clicking.
What year alt should I ask for?
norville
1986 C10 Scottsdale
5.3, TH400
Old 09-03-2004, 07:31 PM   #6
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
is the left bulb brighter than the right? i did this on my tail lights. looked like the brake light was on. i needed to turn the terminals inside the plug 180 degrees
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
