Old 11-28-2016, 10:31 AM   #1
Speedracer39
Speedracer39's Avatar
72 c10 from leaf to coil
I'm looking at a 72 c10 and it has leaf spring s on the rear I was wondering if The frame has the mounts already on the frame to switch over to coils this way I could just switch complete rearends and it would be a bolt on process or are the frames different from leaf and coil?
Speedracer39 is offline   Reply With Quote
Old 11-28-2016, 11:26 AM   #2
StingRay
StingRay's Avatar
Re: 72 c10 from leaf to coil
Frame is the same. The cross member where the center bearing for the drive shaft is mounts the rear control arm brackets. You will have to remove the leaf specific stuff and add any of the other coil related bits and brackets. It's good to have a donor frame for all that.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 11-28-2016, 11:41 AM   #3
Speedracer39
Thanks for the quick response
Old 11-28-2016, 04:31 PM   #4
WarMonger
WarMonger's Avatar
I think you will also need brackets or crossmember for the top of the coil springs where they attach to the frame? Early classic sells this along with springs and rear end mounts for the trailing arms.
Trailing Arms and Crossmember Kit
Heavy-Duty Replacement Trailing Arms. One-piece construction. 3-1/2 times stronger than equal wall 2\" round tubing. Supplied with new U-bolts, coils spring cups, polygraphite bushings, integrated emergency brake cable bracket, and all necessary hardware.
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
Old 11-28-2016, 07:59 PM   #5
Coley
Coley's Avatar
The leaf spring rear diff does not have the casting boss in it for the pan hard rod to fasten/connect to, so I think you have to add a bracket (aftermarket?) to handle that.
Some of the guys can weigh in on this if I have that wrong.
All Good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
