Lovin' Arizona Since 1961
You Guyz Got Me Thinking About a Tilt Column and...
I found one at a junkyard, I told him I needed a Chevy van 72-81 complete with wheel. Is $125 a good deal? Thanks, H.
"Religion is like a toothbrush: Everybody should have one, but I don't want yours" - Will Rogers |
Sounds about average. I got a truck tilt for $175 which is also about average.
Post Whore
![]() Join Date: Feb 2000
More likely to see one around here for sale for about $100 - don't know what a junkyard would ask. $125 wouldn't be a bad price if everything is tight and you don't have to worry about it getting damaged in transit.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
The ones I have pulled at a yard have been less than $50.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
I paid $30 Canadian and he pulled it.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
![]() Join Date: Feb 2001
$125 sounds high to me for a van tilt. I'd say more like $50 or $75 if it is pretty nice.
'72 Chevy Blazer |
I got an original truck tilt from another board member for that price, sounds kinda high for a van tilt.
What's the difference, appearance or mechanical, between a truck tilt and a van tilt?
Still drivin' a Rat Rod
The length of the steering shaft.The van is aabout 3 inches longer,the PRNDLL indicator is a little different,and the levers have different handles.that's about it.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
^ Plus the neutral safety switch. It will have to be moved to fit a truck.
See here:http://67-72chevytrucks.com/vboard/s...threadid=63328
its all about the +6 inches
I normally pay 25 - 30 bucks for them locally.
i would call some other yards, and if they have a good price but don't have any on hand...I'd wait untill they do. Also, I would personally go to a pick your own part type place...no rerason to pay some one else for what you can do, and plus it'll let you know a little of what you have to do. |
