06-19-2013, 08:35 PM | #1 |
Suddenly Electrically Dead?
Been driving the truck around all day...6+ 10Mile short trips.
Pull into hardware store on my way home and went to start up and ...Nothing? Dead? Turn the key and Zilch!? Battery is fine, even tried a jump to be sure. Actually took the time to pull the starter. (Yep, right there in the parking lot. Actually was kinda fun as a guy near me had Seager's "Against The Wind" playing for most of the ordeal). Took the starter in to Advance and it bench tested fine. Could anyone be so kind as to point me in the right direction for things to check? Neutral Safety Switch? Ignition Switch? Fuse? When I try to jump the starter at the solenoid, I get nothing there too? This thing has some pretty gnarly PO wiring too. Anyway....I will have time to poke at it tomorrow eve and would love any "Did you look at such and such"s as I can get. Time now to surf this forum for info and probably get side tracked on other topics. Cheers! Posted via Mobile Device Posted via Mobile Device |
06-19-2013, 09:07 PM | #2 |
Re: Suddenly Electrically Dead?
Did ya check your connections at your battery? Even though they are connected it could be a bad connection. Make sure all connections are clean and tight. Every problem needs to be thought of with the simple stuff and then if you rule that out go on to the hard stuff. Connections and fuses are the simple things. Then its onto looking for shorts, burned wires, or even broken wires/ worn through. And insulation on the wires.
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses". 93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+ Members I've met... Mister-B |
06-19-2013, 09:11 PM | #3 |
Yeah...will do.
The "no jump at solenoid" has me thinking that the + is not connected somewhere/how? I'll start with checking the + line to the starter and go from there. Odd though...the all of a sudden part? Posted via Mobile Device |
06-19-2013, 09:11 PM | #4 |
Check the wires that go into the harness in the engine bay, they do come loose over time and make the truck seem like it is dead. Happened with mine a couple times
1995 s10 blazer 4.3 1967 c10 350/350 fleet short 1993 s10 blazer 4.3l 4l60 RIP 6/20/14 2000 mercury sable Thats a how I roll |
06-19-2013, 09:57 PM | #5 |
dazed and confused
Also check the little block on the fender. There should be a hot wire running to a junction block on the fender. Mine corroded over time. It gets power in the truck.
members met: redbaron69, billsbowtie,nc67 |
06-19-2013, 11:02 PM | #6 | ||
"I ain't nobody, dork."
What bigguy69 said... it's called a "Fuseable link" and if it's burned out or corroded it will leave you dead. It goes from the battery to a small junction post on the passender side fender.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
06-19-2013, 11:57 PM | #7 |
Ah...secrets are being revealed to me!
But seriously...I'm a total newb and just figured our what PO means in this forum. The litteral is understood. The figurative is followed by 'ed...as in PO'ed! WHat a mess! And it's mine...so I love it! = ) Posted via Mobile Device |
06-20-2013, 12:01 AM | #8 |
Do a google search for volt drop test. That will locate the problem and any other potential problems.
06-20-2013, 09:48 AM | #9 |
Cleaned & checked a bunch of connections.
Recut & connected battery lines. And VaVoom! Probably the battery lines, but maybe the others. Regardless...she's up and running. Thanks for the suggestions. Posted via Mobile Device |
06-20-2013, 11:52 AM | #10 |
You Bet Man
06-20-2013, 12:22 PM | #11 |
There may be one more possibility, the dreaded HEAT SOAK. Sometimes when solenoid wires are old, the solenoid is weak or ignition switch or NSS has resistance, this can happen too. If it happens again, look at the ammeter whilst turning the key to start, check to see if the radio works, check if it starts in neutral, have someone turn the key while you tap the starter with a hammer.....
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
06-21-2013, 05:31 AM | #12 | |
When my truck loses all power, I turn on the headlight switch. Then I go under the hood and wiggle the wire(s) at the junction block til I see the headlights come back on. Then I know I have my power back. This drove me crazy! I'd get stuck somewhere and tried jump starting, rapping on the starter while someone turned the key(heat soak) and even did a battery swap once. Finally, discovered by accident that the wire from the junction block that feeds the cab power(across the core support) was the culprit. |
06-21-2013, 07:00 AM | #13 |
Yep. Did that too.
I still think the battery leads were the culprit, but ruled that one out while at it. Thanks again for all the input. With help from all of you, the electrical side of things is no longer an enigma-like spirit that lives under my hood? ; ) Posted via Mobile Device |
