Old 06-01-2015, 12:32 PM   #1
Jonlopes
Strange Brake Issue
My truck is having a strange problem with the brakes. The main symptom is I push hard on the pedal and the truck slowly stops. I feel the brakes should have more to them, if I stand on the pedal I cannot make it skid even while unloaded. It does stop but not as good as a Chevelle/ El Camino with 9.5” drums on all 4 wheels. This truck has the huge front discs and equally large 12x2.5 rear drums on the dana 60; though it is heavier it should stop better than an A body with four 9.5" drums? In my experience this would normally be a brake booster issue but the thing is, the feel of the pedal is normal. I have driven cars with bad boosters and the pedal feels hard as a rock and the car is scary slow to stop.
Also there is no pulling to either side while stopping. I already replaced the booster check valve and hose.
My thoughts are:
1. The booster is going bad but not completely there yet. I have never seen this, I have only seen them work or not.
2. This is just how these trucks are, get used to it.
3. Something really weird not allowing either the front or the rear brakes to work.
1971 Cheyenne Big Block Longhorn
Jonlopes is offline   Reply With Quote
Old 06-01-2015, 01:54 PM   #2
geezer#99
geezer#99's Avatar
Re: Strange Brake Issue
What about vacuum?
How much is your motor producing?
Old 06-01-2015, 02:18 PM   #3
cdowns
cdowns's Avatar
I'd check your 4wheels to make sure of adequet fluid flow as somtimes these brake lines get clogged solid with crap and the fluid dont flo
Old 06-01-2015, 05:32 PM   #4
cleszkie
cleszkie's Avatar
Originally Posted by geezer#99 View Post
What about vacuum?
X2. Sounds like your motor is not producing enough vacuum, or you have a faulty one-way vacuum valve at the booster. You didn't make it clear if this was a new problem that developed, or if this is the way it has always been.
cleszkie is offline   Reply With Quote
Old 06-01-2015, 05:59 PM   #5
Jonlopes
I have only had the truck for a couple of weeks and it was like this from the start. I will have to dig out the vacuum gauge and see. The brake booster line goes to a nipple coming off the intake manifold. There are 3 things coming off of there the tranny vacuum modulator, the brake booster and a line going into the cab (I am assuming for AC) I went ahead and removed the hose and capped the AC line.
