Old 09-21-2009, 11:52 PM   #1
americanmusc1e
americanmusc1e's Avatar
It stops.........barely
This is killing me..... or should I say It might kill me.
I started noticing that my brake pedal was weak on my truck a few weeks back. The pedal would go almost all the way to the floor before it would stop. I figured that the back brakes needed adjusting, so I put the truck in the shop and adjusted them...... they needed ajusting. I took it for a test drive.....
1. if I try to stop normally (not hard) it works fine
2. If, when stopping normally, I want to stop faster, and push the brake pedal down more, the system dosen't build any more pressure.....the pedal goes to the floor with pressure, but not enough to stop me fast!!!
3. When I first put discs on the front, the truck would skid the front tires on dry pavement. now.... I'm not even close!!!!
the truck ('70 longbed) has power front cross-drilled discs, (switched from discs to drums 2-22-09), and stock rear drums.
at the time of the disc brake swap I put.....
calipers, rotors, master cylinder, prop valve, and booster.......almost new off of e-bay
all new rubber brake hoses
all new front brake hard lines
pads and shoes all look fine.
After the problem started, I swapped in a reman Master cyinder and swapped back out to my old booster.........and lots of bleeding
The Problem Persists........ and I'm still driving it......... scared to death
Suggestions??????
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 09-21-2009, 11:59 PM   #2
texanidiot25
Eat My Rust
texanidiot25's Avatar
Re: It stops.........barely
Are you checking the level of brake fluid? Sounds like a leak some where.
texanidiot25 is offline   Reply With Quote
Old 09-22-2009, 12:03 AM   #3
americanmusc1e
the system seems to be tight with no air in it, I haven't added fluid since I did the disc brake swap....... except for when I bled it
-- Josh
Old 09-22-2009, 12:05 AM   #4
texanidiot25
Eat My Rust
Either a leak or a defective rubber line ballooning some where. To the point where it stays stretched after you let off the brakes..
Old 09-22-2009, 07:20 AM   #5
americanmusc1e
that's what I'm thinking, but all the rubber hoses are less than a year old, and I had someone push the brake pedal while I felt of them, and they didn't seem to be expanding.
-- Josh
Old 09-22-2009, 07:39 AM   #6
cdowns
cdowns's Avatar
i'd try and bleed the brakes first ,just to b sure
Old 09-22-2009, 09:30 AM   #7
68gmsee
Active Member
68gmsee's Avatar
Seems like a strange problem since you say it was working fine before and assuming that this was not a gradual problem but fairly sudden.
If the truck has power brakes and you've changed the master cylinder, swapped boosters, bled the brakes, etc. And if you know those parts rare good, then there's just a few other things that can cause this.
1. Glazed disc pads due to contamination or manufacturing defect.
2. Resticted brake line or hoses -if you haven't replaced the rubber hoses, I'd recommend that. They go bad internally and you can't see it.
3. Bad proportioning valve. If the truck is tryiing to stop primarily with the rear brakes, it's going to have a hard time stopping since most of your stopping force is with the front brakes. The rear just assist.
Forgot to add... Pedal going to the floor is a sign of air in the lines somewhere.
68gmsee is offline   Reply With Quote
Old 09-22-2009, 10:17 AM   #8
OLDIRON69
I'd gravity bleed, sure sounds like air in the lines to me to. I had a wheel cylinder leaking on the rear that caused me some trouble fixed that and still had air inthe lines. I gravity bled and no more problems.
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 09-22-2009, 12:03 PM   #9
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
HMMMMMM.. What does this mean? I wouldn't buy used or use used stuff unless I am going to use it for cores. You don't know what the previouse owner used for brake fluid or accedently poared into the master cylender. Maybe I am an alarmest but when it comes to brakes, I would rather be safe than sorry.
If the power part of the systom works fine, I would look at replacing the mastercylinder or proportion valve. I would also make sure to bench bleed the mastercylinder. I do it in the truck, and pump the brakes many times after the last bubble pops out of the valve assembly. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 09-22-2009, 12:41 PM   #10
MickMc
MickMc's Avatar
It's the master cylinder that needs to be replaced.
Make sure you bench bleed the new one.
Mick
MickMc is offline   Reply With Quote
Old 09-22-2009, 03:33 PM   #11
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Mick
It does sound like fluid getting past the seals in the MC. Try another MC.
PICKMUP is offline   Reply With Quote
Old 09-22-2009, 04:31 PM   #12
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Talking Re: It stops.........barely
Master cylinder sounds like it's bypassing.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 09-22-2009, 09:18 PM   #13
americanmusc1e
I just put it on a week ago!!!!! no change from the old one!!!!!
-- Josh
Old 09-22-2009, 11:36 PM   #14
MickMc
MickMc's Avatar
Sounds like the master bypassing fluid, internally.
OR
the fluid is going somewhere
1. into the booster, maybe
2. into the drums, you would start to see it sometime, and I don't think you mentioned seeing any fluid.
3. the fluid is bypassing it self in the master cylinder, therefore the falling pedal.
This does sound like a falling pedal, and that would indicate a faulty master cylinder.
If you're pressing and pressing and the truck won't stop, thats lack of pressure. These trucks develop pressure very easy, (a leverage thing) so again a master cylinder problem
Maybe, just maybe the proportioning is stuck. That would not make the pedal fall away, but would make the truck not want to stop, i.e. all the brake to the front or rear, causing a weird braking feeling.
I'm going to re-read your post again. maybe I missed something
If there is any air in the system the pedal force will compress it and the pedal will feel very bad or low.
New hard lines=lots of bleeding, air bubble somewhere.
Are the calipers installed with the bleeder screws on top (pointing up) if not air bubble.
Also change one thing at a time, changing the master and the old booster at the same time adds alot of variables.
Clamp off the rear rubber hose with some vice grips and drive it around the block, tell us how it feels, maybe we can isolate this to either a front or rear problem.
Be Careful
Mick
Old 09-23-2009, 12:26 AM   #15
mclairmo
If you have no leaks and no air and the master is good, as you say, then the pedal should not go to the floor.
mclairmo is offline   Reply With Quote
Old 09-23-2009, 07:25 AM   #16
highperf4x4
If the pedal goes to the floor whether it has pressure or not then you're losing or bypassing fluid somewhere. It's usually in the master cylinder.
You may have damaged the new master cylinder when you installed it. You have to bench bleed them or you'll ruin the shaft seals. In other words, if you just stick it on and use the pedal to bleed the master cylinder and the brakes at the same time then you're damaging the seals. It won't necessarily shoot the fluid out the back of the master cylinder but it can bypass the seals back into the bowl of the master cylinder. The best thing to do is to install the blue caps that come with it in the brake fitting connections, fill it with fluid, and use a long screw driver to push the shaft in and out. Don't push it farther than 1". If you do it with the cap off, you can watch the bubbles coming up from the shaft. When the bubbles stop then the master cylinder is bled. Don't worry about the fluid that runs out while you're installing it. As long as there is fluid in the bowls it will stay bled. If you pushed the shaft farther than 1" without being bled then you likely damaged the seals. I'd swap it out and try it again.
As for the brake lines, when they fail, they tend to do the opposite. The lines will "balloon" when you push the pedal as they pressurize. When you let off the pedal the lines will try to collapse again and this continues to apply pressure to the calipers. You will lose stopping power because it overheats the pads/rotors but you generally feel the brakes fighting you and you can smell them burning like a clutch.
Another possibility is the proportioning valve. I don't know if your truck still has one or if it ever had one since it was drum brakes to start with but they can cause problems. It might be killing the fluid to the front calipers. The rears won't do much to stop the truck themselves. You can usually test this by opening the bleeders on the calipers and checking the fluid flow. If they're getting the proper pressure they should shoot fluid all the way up into the fender wells. Way more pressure than what you get from the rear drums.
I'm not trying to imply that you don't know any of this, I'm just offering the info in case it helps.
highperf4x4 is offline   Reply With Quote
Old 09-23-2009, 08:14 AM   #17
americanmusc1e
clarifing, replaced Master cyinder first(I bench bled it thoroughly), then booster.
I'M FAIRLY CERTAIN THAT I'M NOT LOOSING FLUID. (no visible signs of fluid and master cylinder stays full)
and I'm fairly certain that the porportioning valve is not "popped"
-- Josh
Old 09-23-2009, 09:14 AM   #18
highperf4x4
I don't see that there's too many other things for you to check bro. Trace your metal lines I guess and see if one got crimped.
What you described indicates master cylinder. Like I said, you won't always see fluid leak out or disappear. It could bypass the shaft seals back into the bowl. But if you're sure it's good then I'm at a loss to offer you more options.
There's only so many things it can be and if it worked good when you installed the disc brakes it should still be working good now unless one of the items we discussed has failed.
If I were close, I'd help ya check it out. Goodluck
Old 09-23-2009, 09:51 PM   #19
madmaxp01
I had a very similar problem on my '67. I put on a new booster, master cylinder, checked my lines for crimps. Nothing worked.
Are you getting an abnormally small amount of fluid escape when bleeding at the brakes?
I was.
Then I changed the proportioning valve. This fixed it.
I would just go ahead and change the valve. Cancel out all the variables.
Good luck.
madmaxp01 is offline   Reply With Quote
Old 09-23-2009, 10:00 PM   #20
highperf4x4
I was.
Good luck.
Did you check this yet?
Old 09-24-2009, 07:22 AM   #21
americanmusc1e
where do I get a porportioning valve from????? the ones I saw on the internet were $70+
-- Josh
Old 09-24-2009, 10:49 AM   #22
madmaxp01
Yeah, $70-$90 sounds about right. I can't recall where I bought it from online, but i seem to remember it being about $80. Money well spent, though.
Old 09-24-2009, 01:32 PM   #23
highperf4x4
I suppose you could go to salvage but I'd prefer a new one.
You don't need those poly motor mounts right now. Get your money back on those and buy a new valve.
Old 09-24-2009, 02:36 PM   #24
monte0185
monte0185's Avatar
I second this. Had this issue myself.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 09-24-2009, 02:45 PM   #25
ERASER5
ERASER5's Avatar
Here ya go.
These guys know there stuff.
By the way, if you decide to try another MC, before you return this one, pull it a part. the is only 1 snap ring, and the gut slide out. Look at the O-rings and look for debris. My "new" MC was so full of crap that the ports were clogged. I cleaned it, assembled it and amazingly enough, it worked like it was suppose to.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
