Old 03-20-2004, 11:25 PM   #1
cdaniel
Question 72, A/C-heat fan switch, melted plug
It's the second one I've seen switch plug has melted the causing contacts to toucha and the fuse to blow. Anyone else run accross this. Is there a solution to the cause?
cdaniel is offline   Reply With Quote
Old 03-20-2004, 11:42 PM   #2
jhow66
jhow66's Avatar
It is cause by loose connections. The old connector blade on this post heats up from being too loose causing the metal to loose it's tension. Before adding a new switch take the wire out of the connector and replace the blade. Should cure your problem.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
