upgrading to an older model
Having problems lining up the pulleys
I'm having my brother-in-law put the motor/tranny in my '68 stepper and we are having some issues. The motor is a 307 originally from a '70 (I think) fleetside, the guy I bought the motor from snagged the water pump (I can't complain I paid $20 for a running 307
68 stepside, short-box, multi-colored (for now) ![]() ![]() ![]() |
It's a catastrophic success.
![]() Join Date: Jan 2003
Re: Having problems lining up the pulleys
Man you can get into a hornets nest when it comes to mixing and matching pulleys. I dont know all the configurations and if you throw in 73+pulleys it just complicates things. I know there is a short water pump and a long and the pulleys dont all enterchange. I suggest look for a motor that has a simular set up to yours and measure and match the pulleys.
Never Ending Projects
Agreed, you can have short or long water pumps and the pulleys are different between those two. You really can't mix and match. Everything (pump, pulleys, brackets) needs to be either short or long pump style.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
![]() Join Date: Nov 2004
Yup, I learned all that crap the hard way when I installed my vintage air A/C kit and I tried to mix and match stuff, ended up getting a short water pump and all short WP pulleys as even the pulleys are different. You can click my vintage air install thread in my signature so see some of what I had to do. Read posts 9, 10 and 11 and check out the pics in that thread.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 08-13-2008 at 11:31 AM. |
The 67-72 small block v8 trucks all used a short water pump. If you have any local salvage yards, look for a 67-72 chev-gmc and the altinator will be on the drivers side with the short water pump. Grab the pulleys and you should be good to go.
Built 4 Speed
Wow i worked on this today.
yeah i have the same issue on my 69, motor is 84 or somthing... From the crank pumps in about a 1/4 i used some 1/8 washers to get it closer since im not using a mech fan. and that got the alternator,waterpump crank fairly lined up. now my issue is that my power steering is 1/4" tucked behind the crank pully. i got a complete set of pullies on my big blouck (serpentine) im gonna give them all a look over see if i can make somthing work there. ill keep you posted.
1969 C/10 Short Box: 496/T-56 in worx. ![]() "To Be Old And Wise, First You Must Be Young And Stupid" |
