Old 04-09-2013, 04:30 PM   #1
Groove_hunter
Wink 1968 4/6 drop questions
I'm having a 4/6 ECE drop kit installed on my 1968 SWB step side tomorrow and had a few questions. I'm already dropped quite a bit from the PO's lowering attempt with cut springs, so this hopefully will be a big ride improvement. Some vehicle details in case these matter: Coy 18/20 C5 wheels, Boyd rear tank, no C-notch, Proxis S/T 295/45/20 (back) and 255/45/18 in the front and a 5.3 LS swap. Right now my front suspension bottoms out easily.
Questions:
1) How much is everone cutting the bump stops after this install (50%?)?
2) Is there likely going to be issues getting the rear track bar installed with the Boyd tank? How are folks getting around this?
3) Is anyone welding the shock relocators or going with bolt on only?
Thanks in advance..
P.S.
here are a few pics from today after the wash for some eye candy. Great 83 degree FLorida weather.
Groove_hunter is offline   Reply With Quote
Old 04-09-2013, 04:52 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: 1968 4/6 drop questions
My opinion is
1.6 in is a lot without a C-notch
2.If they're using 2 1/2 spindles and 1 1/2 springs it might get better.
3.You'll need an adjustable panhard and if the original fits the adj should.
4.shock relocators could go either way.Many here have done them without removing the rearend and used bolts.
Good looking truck,just remember my comments are opinions only about your planned mods.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 04-09-2013, 08:51 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You're using good parts there. I've done a lot of ECE 4/6 drops on these trucks.
You're fine in the back without a notch.
I remove the rubber snubbers in the front entirely and just use those little button urethane ones.
Bolt the rear shock relocators on. They are held in place by four rivets total. Once you remove the rivets and the original upper mounts, the ECE brackets will simply bolt into place without any problems. They even include the hardware with the ECE relocator kit.
I have never personally seen a tank like yours but I'd think your concerns are valid. If you're using the ECE super track bar, it does go down to the right trailing arm which might interfere with your tank. Worst case, don't use the super track bar and just use an adjustable replacement bar. They go right in where the stocker does.
Old 04-09-2013, 09:11 PM   #4
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
I have everything you are talking about installing on my truck and I have no issues. I used 2.5" drop spindles and 2" springs in the front and 6" springs in the rear. I removed the original front bump stop and installed a smaller one from energy suspension. I cut the rear bump stop about 1/4" below the frame and it has done fine. As stated above just bolt the shock re-locators in place. I have had no issue with the super track bar and the Boyd tank.
On another note I really like your truck. I talked to the PO when he had it listed for sale (Birmingham?) but couldn't come up with the cash at the time. The engine swap looked to be very well done and the interior is also sweet. Great buy! Do you have anymore pics here on the board? If not, post them up! Sweet Ride!
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 04-09-2013, 09:19 PM   #5
67anthony
Great looking truck i have this set up you will love i have a c notch but it did fine with out it
67anthony is offline   Reply With Quote
Old 04-09-2013, 09:22 PM   #6
slammed1
1972 Chevrolet SWB
slammed1's Avatar
Great looking truck,and I bet it will ride tons better than before.
My New thread with pics (not my build thread yet.)
http://67-72chevytrucks.com/vboard/s...46#post2573646
1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project.
1980 Camaro Inherited when father passed,68K Miles
2003 Ford Mach1 FUN as Hell!!
2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot)
2004 Dodge Ram HEMI 10" lifted on 37's and 2wd.
slammed1 is offline   Reply With Quote
Old 04-23-2013, 10:29 PM   #7
Groove_hunter
Finally got the ece 4/6 kit installation completed. Was not as straightforward as I had hopped but worth the effort. Seems my 68 was a mix of 71 and stock 68 components which didn't let the drop spindle go in as an easy bolt on affair. I went ahead and had all the front end components replaced as well. The ride is much improved over the old heated coils as well as the steering feel. The rear 20" coys barely fit but looks like I will be ok without a notch for the driving I typically do. The front end has plenty of clearance with the 18" rims. I did have to cut off the passenger side exhaust behind the muffler to clear the new pan rod bar and will need to get a custom exhaust to reroute that piece. that was the only uh oh issue..
Here is a quick iPhone pic showing the new stance. The front is about the same but the back is down a couple of inches. I will post a few more under chassis pics when I get a chance.
Old 04-23-2013, 10:53 PM   #8
67anthony
Looks great if that helps !
Old 04-24-2013, 07:44 AM   #9
C10_ustacould
Sweet!!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 04-24-2013, 08:02 AM   #10
shawno72
C/10 junkie
shawno72's Avatar
Looks awesome
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 04-24-2013, 08:36 AM   #11
Sammy
Looks good. My 67-69? project's frame is using similar aftermarket items that you have. With the exception of being bagged. ECE drop spindles, Super TB, and shock relocating bolted on. 18" Coy 57's all the way around. So the Boyd Tank was on my radar and I am very interested in interference with the boyd tank issue. Did you have any issues with a front sway bar? This is one of my other concerns if I decided to add it at some point.
Nice looking truck and a killer color to match!
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 04-24-2013, 08:48 AM   #12
BossHogg69
motor exploder
BossHogg69's Avatar
Groove_hunter - that is one fine looking ride. Well done on the drop!
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 04-24-2013, 10:17 AM   #13
Groove_hunter
Final measurements and a few under chassis pics. I took the measurements from ground to the center of the wheel well. Before/after.. Passenger front : 28/27.5, driver front :27.5/28, passenger rear : 31.5/30, driver rear : 31.5/30.5. So basically I'm down 1.5 inches in the rear with the ece 4/6 relative to the PO's heated coil lowering. Hugh difference in ride quality!! My front sway bar has 5.5 inches of ground clearance and the A arms have 4 inches. The adjustable pan rod bar didn't have any interference issues with the Boyd tank just the passenger side exhaust exit. Looks like if I had 18" coys on the rear I would be close to level.
Thanks for all the help from the forum.
Old 04-24-2013, 10:18 AM   #14
Groove_hunter
More pics.
Old 04-24-2013, 10:19 AM   #15
Groove_hunter
Old 04-24-2013, 10:22 AM   #16
Groove_hunter
Passenger side exhaust exit had to be cut. It is a tight fit with the rear tank and longer bar.
Old 04-24-2013, 10:24 AM   #17
Groove_hunter
Peanut butter and candy green, looks like a piece of hard candy lol.
Old 04-24-2013, 10:44 AM   #18
Sammy
Great. Your question about bump stops..Have you tried to just remove them and see what or even if they will be needed? Wouldn't the shocks n springs prevent it from complete collapse anyway? You can always reinstall them..Just an idea..
Old 04-24-2013, 08:57 PM   #19
captnblood34
Awesome! Ive got a 69 step here on the WEST COAST!!!! I was literally searching for info on Exactly this. I was researching the same kit, with some exceptions (already pieced some parts together). Looks great, ordering mine right now. PM me if there were any other hiccups I should anticipate..... sweet ride
Jay
captnblood34 is offline   Reply With Quote
Old 04-24-2013, 09:51 PM   #20
bigguy69
dazed and confused
bigguy69's Avatar
Good looking ride
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 04-24-2013, 10:27 PM   #21
tommyd241
tommyd241's Avatar
Beautiful truck!
'68 SWB Fleetside
'98 K1500 Silverado
tommyd241 is offline   Reply With Quote
Old 04-24-2013, 10:51 PM   #22
cswolley
Truck looks great! What is your wheel offsets?
cswolley is offline   Reply With Quote
Old 04-25-2013, 10:14 PM   #23
1967chevytruckguy
hi groove hunter what width rim did you use in the rear and where did you find those gauges in your truck ?
1967chevytruckguy is offline   Reply With Quote
Old 04-26-2013, 02:45 PM   #24
Groove_hunter
The gauges are auto meter and were installed by the PO. Looking behind the gauge face it looks like all the old circuit board was removed and the new gauges were clamped in place right on the bezel. This truck is a LS swap so all the gauges work with the new 5.3 computer outputs. I think the Quad gauge was used to keep the stock 3 hole bezel on the base/stripper truck. I believe that the rear rims are 10" wide and 5" offset but I will check and post when I get a chance to look.
Old 04-26-2013, 11:17 PM   #25
fastnotch89
fastnotch89's Avatar
How close are the rear's from the inside of the fender? Im running 22's in the rear and was thinking about only going with the 3/4 drop but if i can go down more i am, thanks for your help.
fastnotch89 is offline   Reply With Quote
