![]() Join Date: Dec 2004
electric cooling fan question
ok guys,i know there has been a lot of discussion about these,i have 2 12" cooling fans mounted on a shroud,i also have a thermostat switch that autimatically turns them on when the water in the radiator reaches 180 degrees,and then they shut off when the water in the radiator reaches below 180 degrees,which is not for several minutes after the truck is off,now,my question is,is it better this way,or to just wire them in so they turn on when the truck is started and they shut off when ui turn off the truck,or is it better the way i have them now,im just curious,i have a lot invested in my truck,and this is my first time w/ electric fans,i just didn't notice alot of movement in my temperature guage when i took it for its first road trip to get the bed done,any and all help will be much appreciated.thanx...mike
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
WTB this ad
I have electric fans on everything we own (except for my tractor
thats what i was thinking,but the way mine works now,i bet it is on a minimum of 7 minutes after i shut the truck off,any other help would be great
#4 | |
The LuvShack Garage
HE AIN'T KIDDING W/ YA EITHER ![]() ![]()
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#5 | |
WTB this ad
![]() Join Date: Jun 2003
My Flex A Lite thermostat went out just over a year old. If you do not have the manual on switch installed you may want to or just make a jumper wire to run the fans off of the key. I was lucky when mine gave up the ghost, in the driveway. I now have a backup manual on connection opporated by my key if it goes out again.
its all about the +6 inches
Wire it to the ignition switch. This way if the relay goes bad, nothing will happen untill you hit the ignition. Sometimes the relay will short out internally and your fans will stay on all night...or untill your battery dies, which ever comes first.
If you notice, all the new cars have it wired this way. |
