Rear disk kit
Anyone use this company or kit? Seems like a good price.
http://www.classicdiscountparts.com/...lt-%26-12-Bolt Or this kit? http://www.ebay.com/itm/230845329214 Last edited by Vova; 10-17-2013 at 02:57 AM. |
Re: Rear disk kit
DAMN those are good prices I just whipped out ecklers and that's half what they want
http://67-72chevytrucks.com/vboard/s...d.php?t=597052 |
Re: Rear disk kit
damn cheap!
I stopped adding up how much I spend on my builds, it only makes me doubt my sanity knowing I've spent more than 9 times it's original value new.
![]() Join Date: Apr 2008
Re: Rear disk kit
Good price.
Re: Rear disk kit
Didn't say if their 5 or 6 lug, totaly different part # for either one on the next brake page?
I don't think we get smarter as we get older. We just run out of Stupid things to do. |
Moderator
![]() Join Date: May 2007
Re: Rear disk kit
I have heard nothing but good things about the eBay kit. It is complete with e brake too. A lot of these kits sold have calipers that have an e brake built in...BUT you are on your own when it comes to figuring out how to get the proper cables and route them to actually make the e brake WORK.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
![]() Join Date: Oct 2012
Re: Rear disk kit
hummmmmm.......i need these
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
Re: Rear disk kit
LeddZedd.......... Do you know if they are 6 lug or 5 lug?
#9 | |
Re: Rear disk kit
![]() eBay one says 5 on 5 rotors.
Oscar '72 Shortbed Fleetside '95 Jimmy 4X4 '69 GMC Custom Camper |
Re: Rear disk kit
Looking closer at the Classic Discount Parts kit is for 64-72 A Body, 67-69 F Body, 68-74 X Body. Not sure it will work for a Truck 12 bolt.
#11 | |
Old member
E-bay add is 5 lug
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Rear disk kit
I think I'm going with the ebay kit and this booster. http://www.ebay.com/itm/330948170536...536%26_rdc%3D1
#13 |
Re: Rear disk kit
Never done it on a truck, but adding rear discs to B-Bodies has been nothing but grief for me. Even with floating calipers the amount of slop allowed by a C-clip setup seems to really compromise the rear discs so that your brake effort first has to align the rotors within the calipers (or slide the calipers) before it does any actual braking.
That's the part I hate. Anyhow, unless you're building for a road course, towing, or show points, rear drums are all you'd ever need.
#14 | |
Re: Rear disk kit
#15 |
Old member
Well I haven't decided yet but after the 6.0 install I'm either doing a disc swap are a posi unit in the 71.
#16 |
Re: Rear disk kit
Make sure to get a disc/disc proportioning valve.
#17 |
Re: Rear disk kit
This one comes with the booster.
http://www.ebay.com/itm/330948170536...8170536&_rdc=1 |
#18 |
Re: Rear disk kit
Cool deal. $200 for booster/master/prop seems cheap
#19 |
Re: Rear disk kit
You can get 5 or 6 lug from the ebay seller, he also has complete front+rear+boost kits for 1050+ shipping, or 1130 for the nickle plated booster.
I haven't tried them yet but a member by the name ' Pick ' said he ordered the 4 disc kit last week and is going to review them if anyone is interested. Here's some pictures from his build thread.
1970 GMC Last edited by Syndrome; 10-18-2013 at 09:38 PM. |
#20 |
Re: Rear disk kit
What about sourcing the rear disc set up from a donor truck? Would that be a less expensive option? I don't recall what year model GM vehicles will interchange, but seems like I remember someone posting about it. Anyway, just a thought.
#21 |
Re: Rear disk kit
here is a link to a rear set similar to ebay
http://www.autocityclassic.com/index...mart&Itemid=66 I got these at the Carlisle show. They bolt up fine but, as mentioned above, the ebrake doesn't come close to fitting even though they give you another ebrake cable. I also had to move the ebrake cable bracket on the trailing arm backwards to a pre-existing hole. 5 lug only I think. I think others have found the front brake setup off an Astro/Safari van fits the rear of our trucks. |
#22 | |
Re: Rear disk kit
1968 SWB Stepside "Bella coming home" "Bella's Build Thread" A master in the art of living draws no sharp distinction between his work and his play. He simply pursues his vision of excellence through whatever he is doing, and leaves others to determine whether he is working or playing. To himself, he always appears to be doing both. L. P. Jack |
#23 |
Re: Rear disk kit
Ttt
