Old 02-28-2007, 01:00 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
wobbling fly wheel and converter...HELP!!!!
i just built a 350 mated to a 700r4 for a friend. we started it up yesterday and the engine ran great. however, the there was smoke and a loud rattling sound coming from the tranny. when i looked there was oil dripping from the converter area and the flywheel and converter were wobbling. i shut it down immediatly. what would cause this? i torqued the flywheel down properly and it was flush on the crank. what is going on?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 02-28-2007, 01:08 PM   #2
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Re: wobbling fly wheel and converter...HELP!!!!
Was the torque converter properly seated on the trans shaft? The Flexplate may be warped or the bolts are to long (flexplate to crankshaft).
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 02-28-2007, 01:14 PM   #3
Bowtie001
Project underway - finally.
Bowtie001's Avatar
I agree with both of those. I would tend to think that the converter was not seated properly. When you install a converter you have to rotate it until it thunks into place, then again and again... there can be 2-5 thumps before it's really in.
Not sure what damage it'd do to your tranny though.
-Brian
1972 GMC Pre-resto... awaiting allocated funding.
Bowtie001 is offline   Reply With Quote
Old 02-28-2007, 02:03 PM   #4
3/4tonterror
3/4tonterror's Avatar
if its tranny fluid leaking then it sounds like the converter is not seated.if its motor oil, then the crank may be bent.also make sure the flexplate in on right [not backwards]i had a friend do that, and when he started it the converter bolts hit the block making it wobble with loud noises.
3/4tonterror is offline   Reply With Quote
Old 02-28-2007, 02:54 PM   #5
bigblock69
Junior Member
You may want to check and see if the crank pilot diameter matches the diameter of the corque converter crank insert. Hope you did not hurt the transmission. Good luck.
bigblock69 is offline   Reply With Quote
Old 02-28-2007, 05:44 PM   #6
crm318
crm318's Avatar
well i found out that one of the bolts was loose and i replaced it. everything is aligned and no more clatter. however, its still dripping fluid. i think that the front seal needs to be replaced. how might i go about changing that out? is it difficult? how much do they sell for?
1972 Cheyenne
Old 02-28-2007, 05:53 PM   #7
cableguy0
the seal and bushing in the pump is probably wrecked. it will take a matter of seconds to destroy the bushing with a wobbly converter. also you need to check and make sure the snout on the converter isnt torn up
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 02-28-2007, 06:40 PM   #8
corn
If you didnt break the front pump in the tranny & it your trans still works, you may just have a seal leaking. You need to slide the converter up to the flexplate if its in all the way. If everything is good & you just have a leaky seal, you can SOMETIMES cheat it with a flat washer between the converter & the flexplate on each bolt. That will make the seal run on a different spot on the converter yolk where it is probably grooved & making it leak. Not really the reccomended way of doing it, but Ive seen it done with good results...
corn is offline   Reply With Quote
Old 02-28-2007, 07:02 PM   #9
rage'nrat638
rage'nrat638's Avatar
Question Re: wobbling fly wheel and converter...HELP!!!!
dude you got the worst luck i ever seen. is your buddy ready to shoot you yet?
rage'nrat638 is offline   Reply With Quote
Old 02-28-2007, 10:02 PM   #10
crm318
crm318's Avatar
well we both are working on it so we share the blame. we dropped the tranny. we are taking it to a shop tomorrow where they will look at it for free. i think that the converter wasnt fully seated. ill keep you posted.
1972 Cheyenne
