Old 05-02-2008, 10:04 PM   #1
Super-Dave
Super-Dave's Avatar
Ball joints
68 3/4 ton upper/lower A-arms, 88 spindles 3/4 ton, what ball joints?
Brothers has 71- 87 GMBJ007 upper
GMBJ008 lower
Super-Dave is offline   Reply With Quote
Old 05-03-2008, 12:16 AM   #2
subalternnavert
Tire goomba extrordianaire
Re: Ball joints
If you have both spindles, check the size. If you want to make it easier for the swap, get '87 or earlier spindles. Hopefully someone else will chime in that knows more.
I was told recently by an old friend that the most telling thing he's seen from me is when we were in a bar with other friends reminiscing and mourning lost loves. The others talked of women and fun. I missed my '64 GMC.
subalternnavert is offline   Reply With Quote
Old 05-03-2008, 12:54 AM   #3
cdowns
cdowns's Avatar
Re: Ball joints
why buy balljoints mailorder and pay shipping when they're available locally over the counter??? especially if theres a question of fit
Old 05-03-2008, 02:32 AM   #4
Super-Dave
Super-Dave's Avatar
Re: Ball joints
Found 71- 87 balljoint for 3/4 ton will work now getting old one out and new ones in. I cant find anyone that has the tubing that sits under the old ball joint to press through. Has anyone done this?
Old 05-04-2008, 08:24 PM   #5
calvinator
calvinator's Avatar
Re: Ball joints
Yesterday i removed the old upper and lower all joints and my drum brakes from my 70, and replaced them with new 73-87 upper and lower ball joints, and the spindles/discs from an 84. its not quite sitting right so it needs bit more work. we had trouble removing the original upper ball joints cause they werre rivoted on. we just drilled them out and chiseled them off. the lower ball joints came out with a hammer as long as you put a sturdy support under the lower A arm. Then, to install the new lower ball joints we just borrowed the "c clamp" tool from our local gas station/shop. worked well. But the wheels are tiled in a lot at the bottom, so Im thinking ill have to remove some shims from the upper A arms.
calvinator is offline   Reply With Quote
Old 05-04-2008, 10:05 PM   #6
cobb_ben
cobb_ben's Avatar
Re: Ball joints
Generally you beat the lower ball joints out with a BFH Big F%^&*@# Hammer. LOL My truck '69 1/2 ton I used 72 ball joints and stuff for the spindles Disc brake conversion.
'69 Chevy C10
400sb-350 crank 400 destroker!!! 377
2.02 dart pro1 alum.heads
msd, holley db
hooker pro-comps-3in exh.
3 spd. saginaw-3.73posi
Flat Bed...want Reg bed...trades?
cobb_ben is offline   Reply With Quote
