Old 12-22-2012, 08:51 PM   #1
mole2000
mole2000's Avatar
Starter Armature Assy. Wear
So I've been having some starter problems for awhile. Pretty much anytime I get the engine started it drains the battery. I decided to take it out and test it to see what I could find. As you can see the armature assembly was worn with a matching area on one of the field coil steel pieces. My first thought is that this is not good, but I don't know how bad it is.
Any experience with this you could share?
Thanks!
mole2000 is offline   Reply With Quote
Old 12-23-2012, 12:21 AM   #2
kelsfine69
18 Till I Die
kelsfine69's Avatar
Re: Starter Armature Assy. Wear
I have seen this on a few starters that i have taken apart. I dont have an answer for you but a push to the top.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 12-23-2012, 12:12 PM   #3
BuiltwithIvy
This is a pretty common problem over time, the starter has a habit of resting in one of three areas, and those areas wear down over time. There are two real solutions, one is to replace the starter (the best solution) the other would be to take a small hammer with you and tap the starter every time you wanna start it up.
"To speak of the art of one loom, the art of one river, the art of one tractor, or the art of one automobile is not preposterous; it is to point to the size and importance of the gap between general knowledge and situated knowledge" - James C. Scott
1969 C10 - http://67-72chevytrucks.com/vboard/s...d.php?t=492064
1930 Tudor Sedan
BuiltwithIvy is offline   Reply With Quote
