09-02-2007, 09:34 PM | #1 |
upper ball joint
hey guys i ordered a front end rebuild kit from classic performance. i put the upper ball joints in today but i dont really like the way its sitting in the arm. when you put that rubber boot through that retainer piece then put it and the ball joint through the hole its a really tight fit. when i tightened it down theres a little gap in the front. the sides and rear seem to be ok.i know this is kinda vague but i dont know how to really descibe it. any help would be appreciated. if this is ok then thats fine i just dont want to get it on there and something break. thanks alot.
1972 chevy long bed. Currently under construction!! Bagged, 383/700r4. |
09-02-2007, 11:56 PM | #2 |
Dave's not here, man
Re: upper ball joint
Are you putting the dust boot on before you install the ball joint? The dust boot goes on after the ball joint is installed. Nevermind this if I misunderstood you. Can you take any pics of the arm with it installed?
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
09-03-2007, 05:50 PM | #3 |
yea im putting the boot on before i put the balljoint in. thats the way it looks to me to do it. heres a pic of the gap in the front.
09-03-2007, 05:55 PM | #4 |
Boot goes on underneath the arm...not through the hole.
Alex 1971 Lil' Red 350 SBC 700R4 |
09-03-2007, 06:11 PM | #5 |
ok that sounds more like it. i just couldnt tell cause when i pulled the stock joint, the boot looked like it was through the arm. what is that thin piece of metal used for? to center the balljoint?
1972 chevy long bed. Currently under construction!! Bagged, 383/700r4. Last edited by orange72; 09-03-2007 at 06:12 PM. |
09-03-2007, 07:10 PM | #6 |
Rubber boot goes through the thin piece of metal. With MOOG the boot and metal are togther as one. The thin metal piece and the rubber boot go under the contol arm. So the metal piece is to hold the boot.
09-03-2007, 07:41 PM | #7 |
how much did the kit cost.
09-03-2007, 08:07 PM | #8 |
Chevy dude you are one smart man. I didnt even think about putting the piece of metal under the arm. i knew it was there to hold the boot but just didnt know how it was supposed to go on there. 49m the kit cost 269.00 from classic performance. it comes with upper and lower ball joints, tie rod ends and idler arm. Its supposed to come with sway bar bushings as stated in product description but i didnt get any. ive got to give them a call tomorow. thanks guys for all yalls help.
