07-29-2012, 09:55 PM | #1 |
wheel hop
i have a 64 c10 with a 9 inch ford rearend it has mickey thompson s 31x16.5x15 on it it wheel hops real bad just wondering what the best traction bar for this set up would be i know they come in differnt lenghts and didnt really know which brand would fit best or maybe some one has a better solution to the wheel hop. thanks
07-29-2012, 10:15 PM | #2 |
Re: wheel hop
sorry i didnt mention that i have coil springs
07-29-2012, 10:49 PM | #3 |
Re: wheel hop
Check your pinion angle, that could cause wheel hop...
My build thread: 1966 stepside http://67-72chevytrucks.com/vboard/s...d.php?t=486223 1965 GMC fleet http://67-72chevytrucks.com/vboard/s...d.php?t=651726 |
07-29-2012, 11:02 PM | #4 |
"Where were you in '62?"
Re: wheel hop
Do you have a picture of your rear setup?
Competition Engineering : Tech Articles HOW "WHEEL HOP" OCCURS Rear Axle Housing Rotation Without Traction Control: http://www.competitionengineering.co...es/chassis.asp http://www.competitionengineering.co...s/chassis2.asp http://www.competitionengineering.co...s/chassis3.asp http://www.competitionengineering.com/default.asp
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 07-29-2012 at 11:07 PM. |
07-30-2012, 12:21 AM | #5 |
60-66 Nut
Re: wheel hop
If you have trailing arms and coils springs, a traction bar isn't going to do any more for you than the trailing arm already is.
I agree with checking the pinion angle, but from what I've read here in the "Racing and High Performance" section, a better shock should help. It seems that a Rancho 9000 adjustable shock is the prefered choice.
07-30-2012, 09:29 AM | #6 |
Re: wheel hop
07-30-2012, 02:47 PM | #7 |
Re: wheel hop
probably need some weight back there, thats a big tire and its going to need a lot of either weight transfer or directly acting weight to keep it planted.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
07-30-2012, 07:10 PM | #8 |
Re: wheel hop
heres some pics.thanks for all the advice. the video on the ladder bars was great do you think they would work for me with the coil springs and the trailing arms?and yes i know i have a break line leaking.going to go fix that right now.and the dust long gravel driveway. not lol
07-30-2012, 08:56 PM | #9 |
Re: wheel hop
I've never raced a c-10 but on my f-body, relocation brackets helped. What the problem is, is the angle of tge arms are too shallow. Suspension hooks better when they angle up to the front. The stronger the angle on my car, the better it hooked. Maybe a bracket on the frame mount where the arms mount and raise it up a little. And pinion angle is a must to get right.
Chris Posted via Mobile Device
1966 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=615165 1968 GTO http://67-72chevytrucks.com/vboard/s...=1#post7650182 |
07-30-2012, 09:16 PM | #10 |
Re: wheel hop
fink64,
My questions would be what are you using your truck for? What is your engine, trans and your rear end gear ratio? Your rear end suspension set up needs to match all of that. In drag racing power/torque produced by your engine must take a direct path to "planting" the tires and "launching" your truck forward. Any power that gets absorbed by the chassis and suspension is power that can’t be used to get you to the finish line as quickly as possible. On my truck at one time I was going to have a 4-Link on my truck. Then I changed my mind and was thinking about Ladder Bars with Housing Floaters. Then me and my dad talked about rear coil overs and I liked it. So that's what we did. My dad actually thought up and made my rear end suspension. 350 cu in/TH350 400HP +/- a hair Mustang II IFS Suspension with 2.00" Billet Aluminum Wheel Spacers. '58 Ford Wagon 9” Rear End (Non Narrowed) (Axle Length 57.25 inches) (3.70 Gear) Wheelbase has been extended to 117". Front wheels: Weld Racing Draglite 90-Series Wheel 15 x 7 Rear wheels: Weld Racing Draglite 90-Series Wheel 15 x 12 Front tires: Falken Visa 912 Tires - 758 P215/65R15 96H Rear tires: Mickey Thompson Sportsman Pro Tire, 29x15.50-15LT
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 08-21-2012 at 07:41 AM. |
07-30-2012, 09:34 PM | #11 | |
Re: wheel hop
07-31-2012, 08:08 AM | #12 |
Re: wheel hop
As stated above, with the trailing arm/ coil spring set up, there is no axle wrap like in a leaf spring set up. There is no traction aid you can add to fix wheel hop on the trailing arm set up.
Your wheel hop is most likely because the truck hooks up too good, and there's no weight in back to hold it on the ground. You could go down a tire size or two, or try some adjustable shocks, like stated above, but the coil over set up, like "1bad62" has, is gonna be your best bet with trailing arms. Ladder bars won't do any more for you than the trailing arms you already have, other than adding some adjustment to pinion angle ("IF" you delete the trailing arms), but if your gonna go as far as to put ladder bars in it, you might as well go to a four link (not a four bar) set up, and have several adjustments. Of course, you could just ease into the loud pedal, slightly harder each time, until you find the point where it starts to hop... Even the fastest drag cars don't start off the line with the pedal to the wood...
1960 C-10 2000 Dakota R/T 1966 Fury I 2dr post 1984 Big Bronco 2002 Durango SLT (Bride's Ride) |
07-31-2012, 10:08 AM | #13 |
Re: wheel hop
I agree with Captfab , better adjustable shocks and relocate them so they are straight up and down , not angled , so that they actually do something ... mounting at an angle reduces the effect of the shock...
07-31-2012, 12:02 PM | #14 |
Re: wheel hop
Robnolimit posted this chart over in the suspension forum about shock angles. Like mentioned before, as much as they're laid down they're not working effectivly.
Shock Angle - Dampening Effectiveness 0* 100% 10* 96% 15* 93% 20* 89% 25* 82% 30* 75% 35* 66% 40* 59% 45* 50% Another thing that will help is raising the front trailing arm mounting points. You can cut/drill the rivets out of the stock mounts and bolt them back on upside down with grade 8 bolts. This loads the tires more.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
07-31-2012, 03:32 PM | #15 |
Re: wheel hop
Here is some more reading info on the subject:
http://www.popularhotrodding.com/tec...e/viewall.html http://www.rodandcustommagazine.com/...g/viewall.html http://www.hotrod.com/techarticles/t...p_suspensions/ http://www.carcraft.com/techarticles...e/viewall.html
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
07-31-2012, 09:55 PM | #16 | |
Re: wheel hop
07-31-2012, 10:12 PM | #17 |
Re: wheel hop
thanks to every one for the input if theres any more advice anyone one would like to give please do i need all the help i can get.
07-31-2012, 10:19 PM | #18 |
Never Ending Projects
Re: wheel hop
Another thing to keep in mind, the frames on these trucks are kind of flexy. When the rear is hooking up, it could be creating some frame flex that loads and unloads and creating the hop. Trying the other ideas might help fix it but you might need to stiffen up the frame some. I would try the easy stuff first but keep this in the back of your mind.
Good luck
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
07-31-2012, 11:02 PM | #19 |
Re: wheel hop
I'll second the thought that frame flex could be part of the problem. The frames are very prone to torsional twisting; bad enough that I'm going in and making X braces for my truck's frame. You didnt mdntion how much hp/tq the engine is making, possibly enough to distort the frame when launching? You could try welding the crossmembers in solid as they are only riveted in from the factory. Adding gussets to the crossmember-to-frame areas will help as well. C channels aren't very strong against twisting forces though, so extra bracing is a good idea.
Another thing- what condition are your trailing arm, shock, and panhard bushings in? Are the newer, or do they have any wear on them? This is the bracing that I'm building for my '66. There will be another matching X brace for the bottom half of the frame rails, and the two will be tied together with more tubing to make the frame stiffer.There will be a second set of X braces under the cab as well. I doubt you'll need to go to this extreme to get rid of the wheel hop though. You can see just how bad the frame flexes with just one rear air bag pumped up. Notice that the front crossmember is still sitting level! Posted via Mobile Device
08-01-2012, 01:01 AM | #20 |
60-66 Nut
Re: wheel hop
There is quite a bit of helpful info on getting these trucks to hook and launch, over in the 'Racing and High Performance' section. There are several members that hang out over there that race the '60-'72 trucks.
08-20-2012, 09:53 PM | #21 |
Re: wheel hop
got my new coil springs this weekend at a swapmeet.
