Old 09-05-2013, 06:55 AM   #1
missinfishin10
Amazed Member
missinfishin10's Avatar
Power Steering Hose?
Hello all, I am finishing up my '71 GMC project and am ready to drive it. Looking for a pressure side power steering hose. The box is an original '71 and the pump is a '95 era serpentine system pump. Is there a bolt on hose out there or does it have to be custom?
Thanks in advance everyone! Jeff
71 LWB Fleetside
1950 3100 Original Project!
missinfishin10 is offline   Reply With Quote
Old 09-05-2013, 08:16 AM   #2
benny70
Re: Power Steering Hose?
It has to be custom made. I swapped in a motor from an 87 camaro in my truck and ordered the hose that fit the pump but the threads are metric. I took it to the hose shop and he cut off the end that goes to the pump and crimped on a new one. It took him about 5 minutes and only charged us for the parts
benny70 is offline   Reply With Quote
Old 09-05-2013, 08:48 AM   #3
Lee H
Lee H's Avatar
All you need to do is use the pump fitting form a 71-72 era pump, it will swap right out with the 95 era pump fitting. Then use your 71 era hose.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 09-05-2013, 10:23 AM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
What Lee said...
I know my local parts store that I use and the local NAPA, both make hydraulic hoses for pretty much any application you can fathom as well. And they are priced pretty cheap.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 09-05-2013, 01:58 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Yes. It's a 1 inch wrench size. Unscrew the fitting from the late model pump and screw the early model fitting into place. Now you can use a stock early model hose. No need for custom hoses.
