Old 07-08-2003, 12:13 AM   #1
'70 C/10 SS500
'70 C/10 SS500's Avatar
Question Inner Fender Prep/ Painting?
This past weekend I pulled the front apart to finally replace my battery-acid eaten pass. side inner fender well. I have a new Goodmark fender well that I assume might be EDP black primered? If so, how should I go about painting it? Should I just mildly abrade the primered finish to give the new primer a surface to hold onto, then seal and paint, or should I just paint right onto the factory finish? Any tips for spray can woes? I'll be painting semi-gloss black then wet sand and polish. I hate painting, never seem to do as good of a job as I envision in my mind, any tips to produce a quality finish with spray paint from a can? For this fenderwell, what grit sand paper to use for primer and finish coats? Am I turning a mole hill into a mountain? Thanks in advance!
'70 C/10 SS500 is offline   Reply With Quote
Old 07-08-2003, 01:06 AM   #2
cheyenne10
cheyenne10's Avatar
TTT
I will be in same delimia soon (I hope). I also worry about fit, maybe install it to check fit first, then pull it and treat underside? Then finish top side and reinstall. What are recommendations for treating bottom as well as top, I'm very curious what works too.
Please share your preferences!!
Bob
cheyenne10 is offline   Reply With Quote
Old 07-08-2003, 07:45 AM   #3
JimKshortstep4x4
Smile
This is what we do. Lightly sand with 220 grit, clean with solvent, (both sides), prime with (2) coats of good primer. Sand primer with 400 grit, clean and spray with Rustoleum semi-gloss, (we use a paint gun and thin paint with mineral spirits). Apply at least (2) good coats both sides. On the underside, we undercoat by spraying foundation tar, thinned with mineral spirits, applying heavily.
It is very difficult to get a good all over finish with a spray can as getting the whole liner "wet" is almost imposssible. If you have to go with a spray can, paint when it is cooler so that you don't develop dry spots.
Jim
Old 07-08-2003, 09:35 AM   #4
gr8scott51
gr8scott51's Avatar
POWDERCOAT
If you can afford it, powdercoating is the way to go. Runs about $200 for the pair up here.
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 07-08-2003, 03:21 PM   #5
Blue68
Blue68's Avatar
Rattle can of Rustoleum. Black, semi-gloss. Just don't leave them sitting out in the weather before you paint or you'll be sanding rust off. Trust me on this one.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
