Old 05-29-2012, 11:28 PM   #1
texassquarebodies
Truck Nut
texassquarebodies's Avatar
Pro-Street Advice Please
I am in the process of rebuilding a 1982 short bed that my Dad and I built when I was in high school--early 90's. It has not been on the road since 99'. I have it running now, close to driveable. Always wanted to tub it.
I need some advice on doin the old school pro street thing. I'm talking 15" wheels here boys-no 20's for me. I want to run a 15x14 rally in the rear with a 29x18 Sportsman S/R radial tires. I don't want the tire to poke much past the rim much.
Should I get my tires and wheels first and then have my rear narrowed?
What back spacing do I need on the wheels?? How much do I narrow my rearend??? I'm putting the leafs on the inside of the frame rails. Do I just swap sides??
Any help would be great appreciative.
Tony Kee
Texas Square Bodies
texassquarebodies is offline   Reply With Quote
Old 05-30-2012, 12:45 AM   #2
Pro Performance
Pro Performance's Avatar
Re: Pro-Street Advice Please
I am not too familiar with pro-streeting, but I definitely recommend getting the wheel & tires first, then cutting the rearend to fit. If you do it this way, you can place them exactly where you want them to go, check for clearance, then cut the rear.
Pro Performance is offline   Reply With Quote
Old 05-30-2012, 12:57 AM   #3
tinydb84
tinydb84's Avatar
Sorry no help here but I was always interested in moving the leaf springs inboard. Tag for following.
Old 05-30-2012, 01:30 AM   #4
andrewmp6
With wheels that big a 4 link is the only way to go if you want it to have traction.
andrewmp6 is offline   Reply With Quote
Old 05-30-2012, 07:31 AM   #5
texassquarebodies
Truck Nut
Not going 4 link. I'm not gonna have a high hp motor in it. Maybe 350hp. Its gonna be a cruiser. I like going fast, but that costs more money than I have
Tony Kee
Texas Square Bodies
Old 05-30-2012, 01:24 PM   #6
tubbedII
needs more $$$
tubbedII's Avatar
Ditto! This is the way I did it with my Nova. Since you're not going with a high HP, there was a post recently about having the axels cut down and resplined here on the board by a vendor.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 05-30-2012, 02:12 PM   #7
PBFAB.COM
PBFAB.COM's Avatar
If you're seriously considering having the housing narrowed up, or an aftermarket one built, then you'll want to have the wheel offset figured out ahead of time. That way you can provide that information/measurement to the rear end shop / manufacture when they go to build the housing.
In the case of axles, so axles can be shortened and resplined as long as they are thicker where the current splines end now. In most cases they are, however there are axles out there that tapper down after the splined section.
Depending on the projected look of the truck you might need to revamp some of the suspension components to provide additional tire clearance. You can move the leaf springs inboard, install a 4 link inboard or outboard, and even change up the rear frame rail section as well. The options are out there.
Here's a link to a build similar to yours that was done in the past, and you could do something similar however using less complicated components such as a bolt-on 4 link and coil over package.
http://www.cachassisworks.com/Storie...AC-009_WEB.pdf
We can provide you with advice as well as suspension components if you decide to alter the rear of the truck.
Good luck with the build and I'm sure it'll be nice to get it back on the road again.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 05-30-2012, 02:50 PM   #8
texassquarebodies
Truck Nut
Thanks for the input guys. Its always good to hear several opinions on things you have never done before. I have in my head how I want it, but want to do it only once. I still need some pics or input on my rear tire/wheel combo.
I want 15x14 truck rallys and 29x18 s/r sportmans. Anyone have pics of that setup??
Tony Kee
Texas Square Bodies
Old 05-30-2012, 02:54 PM   #9
PBFAB.COM
PBFAB.COM's Avatar
That would look good and I'm sure you can locate or have someone build you some wide ralleys these days. Maybe someone like Stockton Wheel Co.
Nothing wrong with a set of M/T Sportsmans or Sportman Pro tires stuffed under a squarebody.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 05-30-2012, 02:59 PM   #10
Pro Performance
Nope, nothing wrong with that at all!
Stockton wheel is a good choice, and Vaughn Machine is another option.
Vaughn Machine
Old 05-30-2012, 07:50 PM   #11
robnolimit
robnolimit's Avatar
Also try Wheel Vintiques. Best to know the wheel/tire combo first. Also, consider mounting the springs under the frame. The wider spring stance will ride better, a lot better. Check into the rear spring kits used by street rod guys for 40 fords, 39 chevys and the like. Speedway has some universal kits for pretty cheap. The springs are a little shorter, flat arc, and have 'car like' shackles for a better ride. For axle width, start with chassis width, + 6" (3" per side for tire bulge and air space) + 2 times the wheel backspace. If you use this, you can contact the wheel company, confirm backspace, and start on the rear end and suspension without having the wheel and tires.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
