12-27-2004, 09:50 PM | #1 |
Cowboy Fan for Life!!!!!!
Anybody using this cool setup???
3" x 16" Stainless Steel Overflow Tank. Pretty sweet for around $35-40.......Opinions????
1967 ShortBed Fleetside 3/4 Drop 350/700R4 Tilt wheel 18 x 8 Torque Thrust II's Future mods: All new gauges & wood bed My Zip is 23002 I ship UPS, USPS |
12-27-2004, 09:55 PM | #2 |
Hippy
I've used them in the past and planning on using it on the next project. sure beats a plastic bottle. But doesn't have the class of a Yuengling can
12-27-2004, 09:57 PM | #3 |
Looks like it should work well. Who makes it??
I know what your thinking.......I have ESPN. Sometimes it's easier to do things the hard way. Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! |
12-27-2004, 10:03 PM | #4 |
Happy to be here
Look on Ebay. They are even cheaper there. I have seen them for less than $20.00...
12-27-2004, 10:49 PM | #5 |
Looks real slick.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
12-27-2004, 11:00 PM | #6 |
my gas saver
i used one on my chevy 2. i took it off before i sold it and plan to use it on my truck (in whatever millenium it gets done)
85' SWB, 4.3/TH350, getting ready for paint 84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black 71`SWB, project ebay feedback |
12-27-2004, 11:17 PM | #7 |
I have been using one of those for several years now. Look at the left side of the grille.
12-27-2004, 11:18 PM | #8 |
I have thought of painting it black!!!!!!!!
12-27-2004, 11:21 PM | #9 |
You can get the smaller ones pretty cheap on there ($20 or so) This one is the biggest one i've seen (3" x 16"). I am looking at this one from bigbauto @ $34.99 +shipping "buy it now". If you see this size cheaper, let me know. I would love to see a pic of one of these installed on our trucks. Thanks, ......Jerry
12-27-2004, 11:22 PM | #10 |
Sorry Mudder, posted before I read your reply. Have you got an engine bay shot that shows your setup? Thanks, .....Jerry
12-27-2004, 11:48 PM | #11 |
Thought I did but cant find it. It's just mounted to the side of the radiator opening with a couple of holes to be drilled for the hoses.
12-28-2004, 12:23 AM | #12 |
Hey Mudder- instead of painting it black, why don't you just get some black tape/graphic material and cover just the stainless that shows through the grill area. You would still have that cool stainless look under the hood without it showing through the grill. Just a thought........Jerry
12-28-2004, 12:26 AM | #13 |
Hmmmmm, overflow tank looks familier.
12-28-2004, 12:30 AM | #14 |
Evenin' Randy, you up watching the game too or just surfin'?......Jerry
12-28-2004, 12:39 AM | #15 |
Wow! That looks a lot better than my red antifreeze jug with a hose duct taped to the top of it!
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open |
12-28-2004, 01:18 AM | #16 |
10/30/19
Go Rams.
12-28-2004, 09:10 AM | #17 |
67-72 Addict!
When I get mine,I plan to mount it on the side of the center grille brace and paint it black. My buddy just had one made just like that.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
12-28-2004, 09:56 AM | #18 |
I was just surfin......now I'm surfin again.
12-28-2004, 10:29 AM | #19 |
PROJECT 7DEUCE
That is a sweet looking set-up...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
12-28-2004, 11:53 AM | #20 |
Junior Member
I put one on the truck, functional and looks good. The unit I bought had a smooth 3/16x1" SS tube on the bottom for the overflow hose. I did not like size or lack of hose barbs, so I machined a SS nut with a small flange, drilled the bottom of the tank to match the flange, tapped the nut to 1/4 NPT and tig welded it to the bottom and then inserted 1/4x1/4 hose barb to attach the overflow hose.
1970 GMC 2500 1994 S10 SuperSport 2000 16' Customweld FishN Boat |
12-28-2004, 11:55 AM | #21 |
I have one of those for my 71'. Bought it on Ebay from: http://cgi.ebay.com/ebaymotors/ws/eB...category=46096
You can go to their EBAY store and look for Overflow Tanks....they have lots of sizes.
Alex 1971 Lil' Red 350 SBC 700R4 |
12-28-2004, 12:11 PM | #22 |
tank
I highly recomend them we use them on most everything we build anymore- hell I even used one on my daughters gocart for a fuel cell (motor was gravity fed and it did require a few mods to the tank - and it would give about 20-30 minutes of run time). The only thing I was ever concerned with when I used as a fuel tank I was removing and replacing the cap pretty often to put fuel in it and since the cap made out of polished aluminum and the tank is stainless and it would be easy to tear the threads up, I never had a problem but it was always on my mind when I was doing it.
Shawn |
12-28-2004, 01:11 PM | #23 |
Got something similar for the remote pwr steering.
Resevoir. Kerry
1969 Chevelle 1990 IROC Z Convertible 2002 Silverado LT |
12-28-2004, 02:45 PM | #24 |
Just came back from taking pics and they suck. It was sort of dark and I cant hold th ecamera still.
12-28-2004, 03:10 PM | #25 |
Chevydude, thats the guy i'm getting mine from just trying to figure out which size is the best for our trucks. What size is your's?
