09-28-2021, 12:00 PM | #1 |
47-55 Sloppy hood hinges
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. |
09-28-2021, 01:42 PM | #2 |
Re: 47-55 Sloppy hood hinges
How "sloppy" is an opinion so it's hard to say. They wiggle around a little bit on mine but once you get the springs on and stuff they are forced to stay more steady.
And it is also VERY common for people to think that the wear in the hinge is making it not let the rear of the hood come down where it is suppose to be. But that is most likely simply poor alignment. You need to rotate the hinges down in the back and it's an odd way to look at it. Even many pros don't get this adjustment. So if that's an issue go to these links and it will explain it. https://www.hotrodders.com/threads/b.../#post-1561503 https://www.hotrodders.com/threads/h...os-too.212388/ Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
09-28-2021, 08:56 PM | #3 |
That's normal when they're not actually connected to the hood.
1951 Chevy Panel Truck |
09-29-2021, 08:36 AM | #4 |
Ok, that's great! One less thing to replace. Albeit those Eddie Motor Sports billet hinges are very tempting, but at $600 I'll pass!
