Old 06-13-2020, 07:13 PM   #1
bigmac73
bigmac73's Avatar
door hinge
should i rebuild or not???
they feel pretty tight and there is no play up or down. however they do not feel smooth, if that make sense??
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 06-13-2020, 07:58 PM   #2
gmc684x4
Re: door hinge
Are you restoring your truck ?
Lube them up with your favorite penetrating oil work them back and forth to get the rust out of the joint
Like deep creep
After see how much play is produced
I am not sure how the repop pins and bushings last compared to the originals in our trucks
gmc684x4 is offline   Reply With Quote
Old 06-13-2020, 08:08 PM   #3
bigmac73
bigmac73's Avatar
Re: door hinge
Actually yes,I have the whole cab stripped for paint and body. and since i am this far i was just wondering about the hinges and i think there is a board member that overhauls them
Mike
Old 06-13-2020, 08:10 PM   #4
bigmac73
bigmac73's Avatar
Re: door hinge
i watched a video on u tube where a guy soaked them in 50% tranny fluid and 50%acetone mix for a week and then pins knocked out pretty easy
Mike
Old 06-13-2020, 08:37 PM   #5
gmc684x4
Re: door hinge
I would rebuild them would hate to have a failure after all the effort to do a complete paint job on your truck to have a hinge problem after your done
The atf and acatone act as a penetrate the rust and loosen the pin up for easier removal
I havent seen one of these truck doors droop yet due to worn pins seen more then a few seize from rust
