Old 05-13-2004, 07:11 PM   #1
Solver
Solver's Avatar
Jeepster376 wins guru contest
Jeepster376 you win the guru contest!!!!!!!!!!!!!
this is update from previous guru needed post on carb problem
I pulled the carb back off and it has black exhaust on the bottom of the carb plates.
exhaust is getting back in!
I ran the numbers on my intake and this is what it lists
1969 -3927184350 - 4bbl- iron - Qjet A B F X Y/255,300,350HP, srv. rep.
It had corvette valve covers on it when I got it but seems maybe they used a corvette intake as well.
I know it's not the original engine in the truck
No idea on the block or heads but I am sure this is what is causing the problem!!!
Now how do I fix this?
I hate to go in and ask for a 1969 corvette carb!
Also hate to ruin this intake as it may be of value by pluging the exhaust ports in it under carb
Any ideas what carb i should ask for that has the exhaust port setup under the front of the carb by the mixture screws?
or do I just replace manifold with a more stock setup?
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 05-13-2004, 07:56 PM   #2
Jeepster376
Jeepster376's Avatar
Cool, what do I win.
The manifold I had like that was a 69 also. If you can't get the right carb for that kind of manifold, I was able to tap the holes and screw 1/8" allen head pipe plugs in there, they always could be removed later if needed. A carb spacer plate may also solve your problem by covering over the whole groove.
72 Cheyenne Super 4x4 SWB
Jeepster376 is offline   Reply With Quote
Old 05-13-2004, 08:00 PM   #3
MACKL
Almost done!
MACKL's Avatar
I believe they make a plate that will completely cover the passage. It is only about 1/8" thick. I had the same problem on my 67 back in 1978, Man that was a long time ago. I have not idea where I got it.
The 1970 SWB Project
Removed 6cyl manual trans, manual everything
V8-350
Auto/PS/PDB
Blazer Fuel Tank
Behind the Marker Light Fuel Fill
MACKL is offline   Reply With Quote
Old 05-14-2004, 09:10 AM   #4
1-PU70
1-PU70's Avatar
Plug the 2 holes like stated before and make shure you get the correct base gasket. It has a little bump on one side. What it calls for is a gasket, metal shim and another gasket. I think Mr Gasket sells a heat insulating base gasket and its several shims and gaskets. You can get that and just use what you need. I think you just have to drill a hole in the gaskets. Good luck
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
