03-28-2003, 07:44 PM | #1 |
convertin a LB to a SB
Does anyone know of a site that may help me figure out how to convert a long bed to a short bed? Thanks!
1970 GMC 1/2 ton 307 4spd 1970 dorF dump runner |
03-28-2003, 08:50 PM | #2 |
custom classic trucks did an article on it in this months issue.
03-28-2003, 09:19 PM | #3 |
Over worked under paid
Shortening
Efab mans got video for sale. For pics go to http://www.ebfabman.com/ pics 14 15 and 16
From GMC Paul "Take 12" out between the front and rear cab mount, this moves the rearend forward and the crossmember that the trailing arms are attached to without changing any distances so no need to have rear driveshaft shortened only the front shaft needs shortened, then remove the front frame to bed mount and and take and move your rear cab mounts back 12", cut your 8" off rear of frame and you have a swb frame. Besides replacing the brake lines with SWB ones you will also need to change your parking brake intermediate cable, swap out your rear taillight intermediate harness for a SWB one or make a loop in it to shorten it up some. Thats it other than the welding that needs done. " http://64.246.42.114/vboard/showthre...ght=shortening
Roger '69 C-10 with GMC front clip billet grill, 283CI, 400TH and 12bolt posiw/3.73 gears |
03-28-2003, 11:55 PM | #4 |
Also a article in the new Custom Classic Trucks issue on shortening the frame....
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
