Old 08-13-2003, 03:37 PM   #1
Bowtie468
Bowtie468's Avatar
HELP !!! Trim Removal
Since search is disabled, i'll have to ask this question again. Whats the best way to remove stainless trim on the front and rear windows? And also the cab divider trim under the rear glass? As for as the windows go, should i just cut the gasket to remove the trim ? I came across a '69 in a salvage yard with flawless trim. I offered the owner $ 40 for the front,rear and divider trim and he jumped on it. Was this a good deal??? Now, if i can only get it off without bending it! I have to go back in the morning to remove it. ( No, i didnt pay him yet ) Yard owner said he had a trim removal if i needed. How would you guys get it off ???
Chris
Bowtie468
Chris
click here to see my buildpage
http://67-72chevytrucks.com/vboard/s...d.php?t=394656
1979 C10 Silverado Big10 SWB
Factory 454/400
Cardinal Red/Santa Fe Tan (original paint)
1969 Camaro X44 LS swap
1968 C10 SWB Fleetside (SOLD)
468BBC MultiPort TPI / Dynamic EFI P4
Black/Black
1963 Nova SS convertible (SOLD)
194 I6/ PowerGlide
Bowtie468 is offline   Reply With Quote
Old 08-13-2003, 04:29 PM   #2
69sixpackbee
Use a good, sharp utility knife and cut the lip off of the old rubbers, pop out the glass and then take them off. Since the stainless trim wraps around the periphery of the glass it is best to take the glass out of the rubber to insure you wont bend the trim. 40 bones is a decent price for all but not "astonishing". I would get it for that price myself if there was nothing else available. The paint divider trim "pops" off of the cab corners and then just slide them across the back outward towards you. These are real easy too.
69sixpackbee is offline   Reply With Quote
Old 08-13-2003, 08:29 PM   #3
Bowtie468
Bowtie468's Avatar
So the glass must be removed before i can get the trim off ? How about the small divider trim running beneath the rear window ?
Chris
Oops !! Just saw your edit about the divider trim !! Thanks !!!!
Chris
Factory 454/400
Black/Black
194 I6/ PowerGlide
Old 08-14-2003, 10:47 AM   #4
69sixpackbee
Chris..it is easiest and best if you pop the glass out of the truck then yo can separate the trim at the corner joints and slide them out of the moulding. It takes all of about five minutes. If the glass is no good anyway then just use a BFH (big f***ing hammer) to make it even easier
good luck!
