05-17-2012, 08:41 PM | #1 |
Looking for camaro clip brake line bracket
Some how in the process of rebuilding my 77 camaro clip for my project truck i have lost the drivers side brake line bracket and retainer. Is there any were on line i can buy this? All the salvage yards around here have crushed all the old stuff. I am installing brake lines and really need this bracket to finish. Its the bracket that mounts rubber line from caliper to sub frame. Here is a pic i found of passenger side mount. I need the drivers side mount and retainer clip.
05-17-2012, 09:19 PM | #2 |
Re: Looking for camaro clip brake line bracket
I'm going to the wrecking yard tomorrow morning, the last time I was there they had a 75ish camaro. I'll see if what you need is there and pull it if it is.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
05-17-2012, 10:03 PM | #3 |
05-17-2012, 10:18 PM | #4 |
You can buy the U clip that holds the line at Autozone and other parts houses. I saw them the other day. That same bracket might be on Chevelles or G body cars.
05-18-2012, 01:00 AM | #5 |
Worst case its an easy angle piece to fab. The horse shoe brackets are on the replacement part aisle at Autozone, Schucks, etc.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
05-18-2012, 04:42 PM | #6 | |
05-18-2012, 06:49 PM | #7 |
an angle piece with a hole in it is holding you back?
fabricate one
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
05-18-2012, 07:34 PM | #8 |
05-20-2012, 10:55 AM | #9 |
I needed some to awhile back got some off a nova
05-20-2012, 12:09 PM | #10 | |
easy peasy
05-20-2012, 12:52 PM | #11 |
That's to easy involes work LOL.
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
05-20-2012, 04:10 PM | #12 |
I don't blame you for wanting the orig. bracket if you can find it. That bracket not only has the locating tab and holds the flex line from the d/s caliper but it also holds the p/s hard line and makes the provision to blend the two lines into one line going to the MC. I've seen some good fabrication but I've also seen junk tacked on to a truck that degraded the entire build. Hang in there.
05-20-2012, 05:31 PM | #13 |
i guess i just like to make stuff
i'll spend 3 hrs on a bracket that cost $5 at the junkyard but if you include the time and gas to go get it, i win a lot of guys think truk is a high dollar build, not. i just make everything
05-20-2012, 06:47 PM | #14 |
I also love to build my stuff ,my motto has always been if you didn't build it is it really yours!!
05-20-2012, 08:52 PM | #15 |
[QUOTE=Speedbumpauto;5390897]I don't blame you for wanting the orig. bracket if you can find it. That bracket not only has the locating tab and holds the flex line from the d/s caliper but it also holds the p/s hard line and makes the provision to blend the two lines into one line going to the MC. I've seen some good fabrication but I've also seen junk tacked on to a truck that degraded the entire build. Hang in there[/My thoughts also. Plus i can spend the two or three hours fab time on something more important. (like finishing my brake lines)
05-21-2012, 09:31 AM | #16 |
Don't get me wrong, I'm a fabricate kind of guy. I just think it's OK to pick your battles especially since, on any custom, there's a ton of stuff you have no choice but make. I also think spending a day with a tool bag rolling in the dirt at some "pick and pull" rates every bit as good as fabricating and sometimes the creatitivity of using "used" parts even trumps it. I also HATE when I know I had something that would work perfectly and now I don't have it.
05-21-2012, 01:15 PM | #17 |
Check with Classic Industries or one of the other aftermarket suppliers. I bought some for my 69 Camaro from them.
Bernie |
05-21-2012, 07:51 PM | #18 |
5 days down and still counting, waiting on a bracket that you could have made in an hour or two
05-21-2012, 08:31 PM | #19 |
05-22-2012, 09:40 AM | #20 |
Go to NastyZ28.com, go to the swapmeet section, ask for one. The good people on there will no doubt throw one at you.
05-24-2012, 05:40 PM | #21 |
I just pulled the bracket and the clip. Send me a pm and we can go from there. Thanks.
05-24-2012, 06:09 PM | #22 |
Fabbing one is very simple and wont take much time. 16ga sheetmetal >cut to orriginal shape > bend> paint> and install. had both mine done in 30 min because I couldn't find any place that sels them near me
