07-01-2021, 09:43 AM | #1 |
Cigarette lighter or USB or Charging port ???
Anyone ditched their lighter for something else??
07-01-2021, 02:41 PM | #2 |
Guest
Posts: n/a
Re: Cigarette lighter or USB or Charging port ???
You have a lighter?
07-01-2021, 03:16 PM | #3 |
07-01-2021, 03:39 PM | #4 |
Bump switch to crank the engine.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
07-01-2021, 04:04 PM | #5 |
Here is what I have. I am going to weld in and finish a plate so it looks like it should be there. It has both USB and USB-C. It also is accurate in the voltage. Super cheap on Amazon.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
07-01-2021, 07:54 PM | #6 |
I ditched the lighter socket and installed an accessory socket wired to the ignition. The lighter still fits in for the original look but it's not functional. I also put in another accessory socket under the dash wired directly to the battery. I can now charge my phone and whatever. My ignition switch does not have an accessory position.
Hairball |
07-03-2021, 10:42 AM | #7 |
Moderator
You can always keep the lighter socket.
07-04-2021, 03:04 PM | #8 |
If you are going to only have 1 socket I'm with Rocknrod, keep the lighter outlet as its more universal. You can always plug in an adapter to go to usb but not the other way around and there are still a ton of items that use a standard lighter socket style plug.
I have been debating putting both styles in my truck since the GMC dash has two pre cut holes near the glove box that would be decent spot for them. |
07-04-2021, 08:49 PM | #9 |
Precut holes?
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 1965 Chevy C50 |
07-05-2021, 10:03 PM | #10 |
At least on my 63 GMC 1500 there are two holes to the left of the glove box that have little caps pushed into them, figured they were a GMC thing since dash is different than the chevy's.
07-06-2021, 12:07 PM | #11 |
Ahh. mines a 64 gmc. different dash
07-06-2021, 03:50 PM | #12 |
I wanted to keep the cigarette lighter housing for originality. I bought an inexpensive volt meter/USB charge port from Amazon and use that to charge my phone. I keep the cigarette lighter in the ashtray with my spare change. Sorry for the blurry look of the volt meter in the pic, its perfectly clear in use.
1965 Chevy C10 283 SM420 Long Fleet "The Old Man" 1970 Chevy C10 350 SM465 Long Fleet "Dave" 1975 Toyota FJ40 "Mr Grinch" 1969 Pontiac Firebird 2001 Chevy Tahoe 2001 Toyota 4Runner |
07-08-2021, 08:35 AM | #13 |
They came on the 1960 models as well.
http://s1299.photobucket.com/user/jb...23904108567829 |
