1961 crewcab
what different frames work?
I am wondering what later frames might work on 60-66 trucks?
I have a 87 suburban that is a 5 lug 1/2 ton,and has a posi, I think it is the same length as a lwb truck, but would it fit under without too much modification? Anybody use other different stuff? |
Re: what different frames work?
I think you would be better off to find a 63-66 frame . 67-72 may work as well but not sure about cab mounts. Then use the 87' front cross member and suspension. It is a bolt in with minor fab work to mount the power steering box. The 87' frame is taller. I used the motor mount pads from 73-87 cut them down and rewelded and they worked great and looks a lot cleaner. Not sure about the 63-66 GMC rear suspension but I know the 67-72 GMC used leaf like your 87' but removing the pads and setting up for trailing arms is no big deal. Good luck.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
Rust Buster
I know the 84 G30 chassis is working good so far...The core support for it and my 65 are both 22 inches from the center of the wheel to the core support. I am taking my 65 core support, cutting off the ends and welding to the center section of the 84 support...retaining all the factory radiator, condenser, mounting hardware from the 84 as well as the position. The ends will let me bolt up my fenders and work back from there. Frame is flat all the way. I will have to cut the drivers inner fender for clearance for the power steering gear box, but so far that is the only snag I see at the moment. I am sure there will be more.
60-66 Nut
![]() ![]() Join Date: Mar 2007
I agree with 502tripower.....a '63-'66 frame would be the best. The '67-'72 frames are the same as the '63-'66 frames except for the front horn for the bumper and the x-member for the radiator. The '87 differential will be about 1 1/2" wider than a '60-'66 differential. The complete front suspension from the '87 will bolt on a '60-'66 frame with minor mods as already stated.
1961 crewcab
thanks guys, that info helps, I was hoping for an easy out... but there never is...
has anybody used that kind of rear? does 1 1/2 wider mean only 3/4 on each side? |
I am wondering the same thing "jonz". I have a 5 lug axle up in the woods that is out of a 87. I was plannin on using in my 65 pickup. I guess we just dont get this lucky right? I also would like to know if 3/4 on each side is a major problem?
Just make up the difference in the backset of your wheels. No big deal.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD Last edited by 502tripower; 01-22-2008 at 02:10 AM. |
![]() Join Date: Aug 2005
C5 Corvette frames work with a little cutting...
![]() ...and by the way 502; the Chevy=Coil, GMC=Leaf idea is a myth. It just depends on how i was ordered. |
60-66 Nut
Yes 3/4" each side. It may or may not be an issue depending on what wheels you use.
UCA63
Chevy:
coils-standard equip. leafs-optional GMC: leafs-standard equip. coils-optional Don't know if options were extra cost or not,but like frizzle said,any way you ordered it. Thanx T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
