Old 07-27-2008, 05:52 PM   #1
floridasteve
floridasteve's Avatar
Advice on power window kits
Since I am in the process of working on the cab I figured now is a good time to ask. Any advice on a kit WITHOUT breaking the bank? I am looking at ones on ebay right now. What I was thinking is that the one with the motor attacked to the track seems to have less of a chance of messing up. I figured that the others that have the cable can catch or jab. Don't know if I explained it correctly or not but makes sense to me. Just thought I would ask for anyones experience in the area. Thanks again and I will include pictures as I do the install.
One day I am going to finish this project!
1949 Chevy 1/2 ton
floridasteve is offline   Reply With Quote
Old 07-27-2008, 10:59 PM   #2
youngrodder
youngrodder's Avatar
Re: Advice on power window kits
I personally went with a kit from Nu-relics. It is a direct bolt in. They are made very nice.
http://www.nu-relics.com/
I was warned by a friend not to use a cheap set up. They can be very hard to adjust. I paid a little over $350.00 w/out switches because I went with different switches. Like most things you usually get what you pay for.
My 2 cents
Good luck
Marc
youngrodder is offline   Reply With Quote
Old 07-28-2008, 12:25 AM   #3
solidaxel
solidaxel's Avatar
Just remember that the door tapers downtowards the bottom and the motor connected to the shaft can only be so low in the door, as oposed to the "remote" motor
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 07-28-2008, 08:02 AM   #4
weldvair@embarqmail.
Solid is right...you need one w/a remote motor. I first tried one with the motor attached & you could not get the door to track angle right.
Don Meyer www.meyerbrosrods.com
weldvair@embarqmail. is offline   Reply With Quote
