Old 12-05-2016, 02:19 PM   #1
harley87ta
C20 Leaf Springs
My C20 has 8/1 leaf springs there 3 1/16 spring pack thickness. I have a chance to get a pair of new 3 5/8 which are heavy duty at a great price. Is the ride going to be that much different? Any input you have would be great
harley87ta is offline   Reply With Quote
Old 12-05-2016, 02:23 PM   #2
74CustomK20
74CustomK20's Avatar
Re: C20 Leaf Springs
How many springsd are in the new pack?
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Old 12-05-2016, 02:35 PM   #3
harley87ta
Same amount of springs just a thicker pack. Same configuration. 3 3/16 are rated 2600 lbs and 3 5/8 rated 3500lbs
Old 12-05-2016, 03:39 PM   #4
Pano
http://67-72chevytrucks.com/vboard/s...d.php?t=723734
This thread discusses a little of what you're asking.
Pano is offline   Reply With Quote
Old 12-06-2016, 10:50 AM   #5
Nodnarb76
Nodnarb76's Avatar
I have been looking into replacing the rear leafs on my 3/4 ton suburban with one ton springs. Does the higher load rating affect ride height?
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 12-06-2016, 04:42 PM   #6
harley87ta
I think the ride height would be the same. If your old springs are sagging then you would notice a difference.
Old 12-06-2016, 05:36 PM   #7
Nodnarb76
Nodnarb76's Avatar
That is what I was thinking also. My stock springs are sagging a little, and I was afraid if I put the heavier springs on it, it would lift it too much.
Thank you.
Old 12-07-2016, 10:43 PM   #8
Alex V.
Alex V.'s Avatar
When I changed the springs on my '85 C3500 I upped to a 3,900 lb.-rate spring (assuming what came out was the standard 3,500#) and stock application Monroe Magnum shocks are nearly fully extended. There's no way to tell how far the old springs had sagged, but it sits a good 3"+ higher now. Ride isn't a lot stiffer, but neither the 3,500 or 3,900 pounders are any semblance of smooth until there's 2,200 lbs. of the truck + at least 500 lbs. of cargo sitting on them. If you're concerned about ride comfort at all, stick with the 2,600 pounders. If it was a 3/4 ton small block truck I'd have probably opted to stay lighter when I replaced the springs, but with a 454 and FF 14-bolt axle I didn't want the truck dragging the ground before I even tested the drivetrain's ability.
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 12-07-2016, 11:10 PM   #9
harley87ta
Thanks for the Great information. Mine are the stock 2600 lbs springs. There 43 years old and one spring has a broken center pin plus worn bushings. There's a set of brand new 3500 lbs springs for $100 and there a 110 miles from me. I don't do any hauling but for the price of them I may just take a chance on them
