Old 08-08-2004, 01:28 AM   #1
SkyBlue72'
2pc. driveshaft needed
I'm in need of a 2pc. driveshaft for a SWB TH350 short tail, if they even make one. Have problems with the the 1pc knocking against the crossmember.
SkyBlue72' is offline   Reply With Quote
Old 08-08-2004, 06:24 AM   #2
MOTHERTRUCKERS
If you were closer i could fix you up, i have 9 of them and the carrier bearing mounts but shipping to AZ would be 30-35.00.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 08-08-2004, 12:21 PM   #3
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
I just pulled one out of a SWB. It is inside, clean & protected. PM for details.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 08-08-2004, 12:30 PM   #4
Burnsman
Chevy Freak
Burnsman's Avatar
Driveshaft
$50 shipped to you. Just pulled out of a 72 shortbed. Brian
69 GMC SWB, 350
70 Chevy LWB, 350
55 chevy gasser, 461
73 Camaro, 496
67 RS Camaro, 406
64 Chevelle, 588
71 Nova, 565
67 Camaro, 461
Burnsman is offline   Reply With Quote
Old 08-08-2004, 11:59 PM   #5
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
I yield to Burnsman...I can't pull, store, box, deliver and ship a driveshaft for $50...that's a "freebie"...go for it!
Phone: 360-956-7170
Old 08-09-2004, 09:44 AM   #6
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Why is it knocking on the crossmember????? When you put in the 1 piece did you remove the carrier bearing bracket?? I have a 1 piece and have NO problems
I'd check out WHY 1st. a 1 piece is much better
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 08-10-2004, 01:35 AM   #7
SkyBlue72'
Well I took out the lower bearing bracket when I restored the truck and just threw in a 1pc, now its lowered alittle and it's knocking pretty bad when I'm hauling my quad in the back.
Old 08-10-2004, 09:50 AM   #8
MOTHERTRUCKERS
Take a torch,plasma cutter or sawzall and trim the crossmember a little bit at a time until it clears.
Old 08-10-2004, 09:53 AM   #9
1970 CST Short Wide
Senior Moment
Where is it hitting?? When you haul your quad the truck goes down, are you sure your drive shaft isn’t to long and its bumping up against the tail housing??, Just a thought. My truck is lowered 3" front 4" rear and I have no problem with a load.
You also say you just threw in a 1 piece, where did it come from or did you have it made.
Pittsburg Ca
94565
Old 08-12-2004, 01:36 AM   #10
SkyBlue72'
Yes, I'm sure its knocking against the Crossmember, because I checked while I had a load in the back, and the shaft is about an inch from hitting the cross member. the shaft came from a wagon which fitted just right.
