Old 05-14-2012, 10:34 PM   #1
ole dollor
ole dollor's Avatar
new to the board
hello everyone, i am new to the board, i am building a 1970 c-10 with a 292 6 cyl,and a four speed trans. this is the first 6 cyl that i have tried to stay with most of the time i just drop in a v-8 and go, i have found out the hard way that if you need anything for a 292 you will have to build it or pay big bucks for parts, like a/c brackets,power steering brackets, i did build the a/c brackets but the power steering brackets i found on e-bay, they are on the way from the guy that makes them, look like a good set up. i have been working on the pickup ( ole dollar) for a little over a year, and have done a lot so far, trying to make it a good driver,and will try and make it pretty later on, just wanted to say hello and that i just found this site, and read a lot of the post and decided to join in and maybe get some answers on my project, and maybe help someone else with theirs. one day i hope to finish ole dollar and have something to be proud of. again hello .......don
ole dollor is offline   Reply With Quote
Old 05-14-2012, 10:50 PM   #2
brianthelion02
Overdrive club
brianthelion02's Avatar
Re: new to the board
Ole Dollar,reminds me of John Wayne's best movie
1971 c-10
1951 3100 chevy
1970 chevy c-30 Sold!
brianthelion02 is offline   Reply With Quote
Old 05-14-2012, 10:58 PM   #3
sharpmark
gidday from new zealand and welcome aboard.
got any pictures of your pickup??
good to see you are sticking with the 292.i took mine out and replaced it with a 305 but the 292 has just been rebuilt as a shortblock and when i get the head and intake/exhaust sorted out it will be going back in.
i look forward to following your progress.
mark
1969 stepside-305/4spd/12 bolt posi
http://67-72chevytrucks.com/vboard/s...d.php?t=477157
1968 pontiac lemans convertible-350/pwrglde/10 bolt
1934 oldsmobile sedan-350/350/12 bolt posi
1930 model a pickup-350/350/jag ind
1928 model a roadster-283/350/9"
sharpmark is offline   Reply With Quote
Old 05-15-2012, 01:25 PM   #4
ole dollor
ole dollor's Avatar
yes brianethelion02 ole dollar was john wayne last horse in his last movie,the shootist, and ole dollor will be my last build, i love old john wayne movies, along with any good shoot em up ,
hay sharp mark i have a good friend in new zealand, he was here in anton and was a visiting preacher, he is back home now....real nice guy.
i will try and get some picks.
Old 05-15-2012, 05:31 PM   #5
ole dollor
ole dollor's Avatar
here are some pics from the first time i got it home and now a year later, not pretty but runs great,
Old 05-15-2012, 05:34 PM   #6
ole dollor
ole dollor's Avatar
and some more pics
Old 05-15-2012, 05:37 PM   #7
ole dollor
ole dollor's Avatar
a few more of ole dollar
Old 05-15-2012, 05:40 PM   #8
brianthelion02
Overdrive club
Nice truck! 6 cylinder stuff is a pain to come up with. I finally found all the power steering stuff for my c-30 and have about givin up on the a/c stuff,lol! Keep thinkin about a v-8 but this thing keeps on runing and gets about 20 mpg! I cant believe how many ppl are around now who dont know who john wayne is!
1971 c-10
1951 3100 chevy
Old 05-15-2012, 05:41 PM   #9
ole dollor
ole dollor's Avatar
and a few more pics
Old 05-15-2012, 05:56 PM   #10
ole dollor
ole dollor's Avatar
brianthelion02 :the ac was a very easy bracket to make, i made my on, the power steering i think is the hardest bracket to come up with or make your self.
i found one already made up on ebay and it is being ship to me . just waiting on it to get here, while i am putting on the power steering ,i will also try and put the new cab mounts on, my cab mounts are shot, if any one has put cab mounts on with out removing the whole cab, as in just raising up the cab and slipping the new mounts please let me know what problems i will have and what all needs to be unbolted. thanks...don
Old 05-15-2012, 07:11 PM   #11
sharpmark
i like it!!
genuine honest daily driver workhorse.
interesting to see the stepside long wheelbase with spare wheel holder on side.
had to look at it a couple of times to work out why it looked different from mine
1970%20chevy%20p%20u%20%20barn%20find%20001
Old 05-15-2012, 07:23 PM   #12
sharpmark
well that didn't work too well---tried to copy your side on picture and post above mine!!!
you should be able to just jack the cab up a couple of inches each side and replace the mounts without to much bother.i did it with mine after i forgot too put the top steel washer on between cab bottom and new mounts and everything was bolted back together.
Old 05-15-2012, 10:20 PM   #13
ole dollor
ole dollor's Avatar
thanks sharpmark i guess that is what i will try, so far it looks like the master cylinder .rad. . and clutch peddle rod ,carpet,seat and seat belts, may have to be out of the way to lift up the cab about 3" or 4 ". i am going to try and do this when i do the change to power steering, maybe with in the next two weeks. also a question on non power steering, is everyone with standard steering on these model pickups real hard to steer, i mean real hard at slow speeds, my son has a 1963 c-10 that has standard steering that can be driven at slow speeds with the palm of your hand...mine takes both hands to turn.
what is yours like...
Old 05-16-2012, 01:36 AM   #14
sharpmark
i changed mine to pwr steering because it was bloody hard to turn at low speeds.as for the cab mounts i don't think you need to go up more then a couple of inches to do it and as i said i lifted mine with brakes,clutch peddle guards etc mounted.the rear bolts are undone from underneath and have captured nuts at the top so apart from getting some crc lube onto the nut i think you should be able to leave seat and seatbelts in.the front mounts have a bolt that comes from the top down so you'll need to lift carpet to get at that.
if you look for Bruce88's post called "its just a pickup" (top of the list under 67-72 projects and builds) and find page 18 post number 446 it shows the setup of the body mounts and will give you a better understanding of how they go.
good luck- mark
