cwgreen1971
pics of new paint and a question!!!!
I finally got my bed back and ready to put the oak floor in. The last two pics is where I am stuck the smaller wood pieces go under the lip on the last pic but is really tight. Anybody have this problem and how did you fix it?
![]() Join Date: Dec 2008
Re: pics of new paint and a question!!!!
If it was me I'd try to loosen the bed side bolts a little and see if that gives you any room. What did you use on the wood? I really like the way it turned out.
00' Z28 ("wifes" car) 92' Mustang w/sbc ![]() 87' GMC Sierra Classic Short Bed Fleet side almost stock 69' Chevy short step carbed 6.0 w/400th trans. Completed w/325 miles on it |
cwgreen1971
Minwax gloss polyurethane, four coats so far, I think I will do two more and call it good...
Huh hope that isn't the stuff people keep saying cracks and shrinks cause that would suck to see as it looks real slick the way it is now.
cwgreen1971
That is one of the methods Mar K suggested to use
If it gets left out for extended periods of time just about all of it will shrink and crack due to the heat cycles of the wood. I used straight poly wet sanded between coats and finished in the same method that is used on bowling alley floors (they buff with a wool type bonnet when the top lay scims over causing the material to bond in a cross pattern and gives strength) on the sides, edges and bottom i mixed linseed oil and poly 1:1 and did the same process. The linseed oil acted as a carrier and the oak gained a ton of weight. Nearly 9 years later there are no scratches, cracks or fatigue. The truck is inside all the time, but we have humidity and temp variations. No problems and do not expect any.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
#7 | |
I take it that you sealed the back side of the wood too? That is very important, it plays a big roll in the ability of the wood to absorb moisture. The expansion and contraction that comes from the movement of water in and out of the wood is what cracks the finish.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
CAN'T FIX NOTHIN
I would not have thought of trying to assemble a wood bed floor fleetside bed the way have done it ? I would assemble the floor wood and cross sill FIRST then bolt the bed panel's on to the floor , same process as you would assemble a metal floor bed , with the bed allready bolted together it will be difficult to install the wood ?? you will have to take a lot of the bolt's loose to allow room for the wood to fit and then tighten everything back up ,,,
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
